Transmission Cooler bypass
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thesvg, Jan 3, 2011.
  1. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    Hey guys, The guy who installed my PTO (for a wet kit) had to remove the cooler, and preferably I really dont want it either. I am always off road and I do not want to get a rock in there and cause a tear. Any how I think he left it leaking a bit of fluid. So I wanted to ask instead of bypassing the system could I just cap it off with some plugs?
    thank you! :D
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    no!! do what i did bought a eaton air cooler and mounted it on the bottom of ratiator cooler fittings and lines cost me $375 hauling about 130000 lbs havent got over 160 deg yet if you plug the lines you might pop a line or damage the little pump in the trans. if any thing hook the lines together so the pump just pumps it through the lines.
    EverLuc and thesvg Thank this.
