Transmission fell out of engine while driving .
Discussion in 'Ask An Owner Operator' started by Southsidetrucker, Sep 3, 2023.
  1. 201
    201 Road Train Member
    12,428
    25,414
    Apr 16, 2014
    high plains colorado
    I didn't mean to call out the size of someones rear end, but trucks just don't require that kind of attention anymore. Heck, a R model Mack I drove,, I literally HAD to get out and check to make sure something wasn't falling off. Sometimes, something WAS falling off, it rode so rough. It's like a modern car, on a 3,000 mile trip, I think I opened the hood once and only then to add washer fluid. I truly believe, someday soon, there will be no hood release and a disclaimer saying" You have no business under the hood, see dealer", and trucks aren't far behind. I'd check the shop, like I say, if it's a reputable shop, they know it's nothing you possibly could have done. Good luck, pal.
    Albertaflatbed, Numb and bzinger Thank this.
  3. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    Sorry Mr.. I was with ya all the way untill you made the statement......[ who would think to go under and check the transmission ].. The answer to that is .. alot of us . When your under your truck you look at everything .. or atleast I try too
    I still can't Imagine there was not some sort of vibration when it started to come loose .. you surely had to notice something was not right .. didn't ya ?
  4. Southsidetrucker
    Southsidetrucker Bobtail Member
    16
    15
    Jul 6, 2022
    You’re definitely right and in the future I will make sure to do that . I’ve only been driving for 3 years now and can honestly admit I’m not the most mechanically inclined individual but you learn new things everyday . There is definitely enough blame to go around from the freightliner dealer and to myself for not noticing .
    Albertaflatbed, Feedman and Last Call Thank this.
  5. AModelCat
    160,330
    The biggest thing you have working against you is the amount of time elapsed. The shop has no idea if someone else removed the transmission since they last touched it. If it was a matter of a week or 2 then you'd have a leg to stand on.
    W923, Albertaflatbed, Bean Jr. and 2 others Thank this.
  6. KrumpledTed
    KrumpledTed Medium Load Member
    485
    1,463
    May 6, 2022
    I’ve seen them slip down or tilt when bolts back out of the bellhousing or they just break. I’ve never seen one plum fall out though, that’s wild.
    Albertaflatbed and wore out Thank this.
  7. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
  8. roundhouse
    roundhouse Road Train Member
    3,179
    7,232
    Jul 11, 2018
    I thought the pre trip exam to get your CDL required you to slide under the truck and touch each part , name the part and say what you were looking for ?
    cause I had to , and I got knocked points off because when I slid out from under the back of the tractor I went right to the landing gear and forgot the fifth wheel .
    I’ve seen a transmission fall out , a few years ago one fell OUT of a truck in Atlanta and killed some one inna car
  9. Gio1980
    Gio1980 Bobtail Member
    11
    6
    Sep 3, 2023
    I wish I had better news for you, but if you didn't inspect the work they said they did, and you didn't ever ask them if they torqued and you could confirm, then you're out of luck.
  10. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,032
    Dec 31, 2010
    Washington, PA
    I fell out of my truck once. I have a few screws loose.
    TexasRiverRat, W923, Siinman and 3 others Thank this.
  11. Truck Turner
    Truck Turner Bobtail Member
    26
    71
    Aug 12, 2023
    My fan hub fell off the block. Two of four bolts showed metal fatigue. Happened at a intersection as I was making a left turn.
