Transmission Fluid Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Misterpreston, Jun 17, 2017.
  1. Misterpreston
    Misterpreston Light Load Member
    96
    4
    Mar 24, 2016
    How often do you need to change your transmission fluid? Ive been told by someone every year and another mechanic said every 30,000 miles
  3. brian991219
    brian991219 Road Train Member
    2,924
    5,816
    Aug 10, 2013
    Lords Valley, PA
    That will vary greatly depending on the transmission model you have and the service category you operate in. Long haul road operations have a different service schedule then off-road or severe duty uses. Eaton Fuller manual transmissions have a different service interval then Volvo I-shift and so on.
    Every major manufacturer has their service information posted online, google the model number of your transmission and look for the service manual. Here is the link to the manual for my last transmission, Eaton Fuller 13 speed RTLO14613b. http://partsmanuals.org/fullerservi...-RTLOF-14613B-transmission-service-manual.pdf
    Also, since most won't follow the link here is a screen grab of the service interval for that transmission, notice the first trans oil change is at 10,000 miles which is a step almost nobody does. Doing the first drain on time removes all the break-in wear particles that happen with any new mechanical device.
    Heavyd and BoxCarKidd Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Find out what trans you have, what type of fluid of you using and what type operation you are in and we can give you the right answer. Yearly or 30,000 miles is nonsense as most cases trans fluid is good to last years or several hundred thousand K.
    F1EXPRESS and brian991219 Thank this.
  5. Misterpreston
    96
    4
    Mar 24, 2016
    I've got the Eaton fuller ultrashift plus. It's linehaul use and synthetic fluid. How often should I replace the filter.
  6. Heavyd
    7,751
    6,184
    Feb 4, 2009
    Linehaul and synthetic is 5 years or 500,000 miles for oil and filter. Filter is optional for most models and only required for 13 or 18 speeds or engines with over 2050 FTLBS of torque.
