Transmission oil cooler lines bypass question - shady or legit?
Discussion in 'Freightliner Forum' started by PermanentTourist, May 6, 2021.
  1. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    Well my understanding of the bypass is that you can't just plug it.
    They actually sell a bypass cover that you put on to it. My transmission is oil-cooled not antifreeze cool. So that may be a different story with an antifreeze cooler.
    I was told that if you're not traveling Long Haul and you're not over 400 horsepower that you can bypass it but I was told not to put plugs in. They said to use the actual bypass cover which costs like 10 or $15.
    Diesel Dave Thanks this.
  3. Diesel Dave
    8,801
    25,637
    Jan 20, 2010
    Hesperia, Ca.
    Lines are still connected. Just had to reroute them slightly and used a coupler to reconnect them together. I’ll keep an eye on the transmission temp gauge. Most likely I will probably go with the “air cooled” route if it starts running a little hot, but I highly doubt that will happened.
  4. QUALITYTRUCK
    1,810
    1,773
    Jun 14, 2009
    romulus,mi
    Dave, I think you will be O.K. I have done it many times, but my customers run mostly midwest with little hills.
    Diesel Dave and Magoo1968 Thank this.
  5. Diesel Dave
    8,801
    25,637
    Jan 20, 2010
    Hesperia, Ca.
    When I drained the old gear oil, it was beyond full. I was expecting it to be like a chocolate milk shake in color due to the coolant leaking in the cooler, but it wasn’t. That’s what threw me off when I had checked the gear oil in the beginning. So when I finally threw in the towel to bypass the trans cooler to see if that was the problem cause the truck was leaving small puddles after being parked over night. When I checked the puddle on the black top, it looked like gear oil BUT, it had a red dye stringy looked. And I had been losing coolant slightly. The pan that had the drained coolant just looked like red dye all over it. Only conclusion was the defective transmission cooler. A drivetrain guru mentioned to me that some of the newer trucks don’t run anymore transmission coolers, there just filled and sealed.
    QUALITYTRUCK Thanks this.
