transmission problem
Discussion in 'Peterbilt Forum' started by acg1, Jan 28, 2013.
  1. acg1
    acg1 Bobtail Member
    hampton new hampshire
    bare with me please as i dont know proper terms for what im about to describe but i'll do my best to be as detailed as possible. so yesterday when i was driving i flipped the switch to go from 4th to 5th and when i went into neutral the transmission started making a constant clicking sort of grinding sound kind of like i was trying to go into too high of a gear and when i tried going into 5th it wouldnt go in i just got the same clicking of trying to go into too high of a gear. so i back down to 4th and try again and it goes in without a problem. also that same day i was climbing a hill in 4th gear loaded and weighing around 99,000 lbs when the trans felt and sounded like it popped out of gear but it didnt pop out the stick. so i dropped down to 3rd and the same thing and a soon as i got up the hill everything was fine. also when im backing up it also feels like the trans is skipping. its an eaton/fuller by the way.
    our mechanic has replaced two air valves and what the parts guy called a puck on the trans but the problem persists and he's stumped. also on a side note its been in the negatives in terms of tempature and single digits during the day whether this has anything to do with the problem i dont know.
    any ideas would be helpful but please only from people who have dealt with this problem or have a really good idea as to what the issue may be.
  3. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    cold temps could cause those type of problems if you have a little water in the lines and not shifting right.
