transmission slow to change range
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gunner76, Dec 12, 2015.
  1. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    I've noticed since It's gotten cold my transmission is slow to go into high range when I first leave in the morning. In order to get it to go into high I have to flip the lever back and forth a few times then it will work fine the rest of the day. then after sitting all night it will act up again the first time I try and change the range. There are no leaks anywhere and I'm running synthetic fluid in the trans. Other winters it was a little slow to shift into high but not as slow as it is now and before it usually wouldn't act up until the temps were single digits or below zero. Now it's been doing it when the temps are in the low 30's. Any ideas what causes this?
  3. DaveLV
    DaveLV Light Load Member
    182
    261
    Sep 18, 2015
    My first guess is the orings in the range cylinder are getting nasty. If you have your air dryer bypassed or have had it for any amount of time might have let moisture in. The silicone grease will bug up over time when mixed with moisture and any oil residue. That would be the first thing I would look at. Could be as simple as replacing the orings.
    Bean Jr. Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Most likely to do with the air control and or slave pistons. If you put something like Marvel Mystery Oil in the lines so it gets to both side of all valves it may correct it temperarerly. Long term you have a reacurring problem and if you do not issolate and repair it will eventually shut you down.
  5. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    Range selector piston or orings, or slave valve is gummed up. Nothing to major hopefully, what kind of tranny?
  6. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    True, or just put an O ring kit through them. Too easy.
  7. Cory wood
    335
    162
    Nov 7, 2015
    Depending on the tranny it's easy. Fro series you have to take the shift top off
  8. gunner76
    500
    137
    Mar 11, 2010
    IA
    it's a RTLO 13spd(if memory serves me). I'll check into the o ring kit.
  9. Cory wood
    335
    162
    Nov 7, 2015
    That's easy then, should be right on the back of the tranny upper right side
  10. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    my truck has done this for years. Just flip it from low to high and wait for it to click in. Put it back in low and it works normal. Don't worry about it.
    When it gets to -20 it sometimes takes a bit.
  11. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    I had the same problem. It got worse as colder it was. The problem was solved as I put an overhauled tranny in. The oilcooler leaked coolant into tranny. I know the leaking cooler had nothing to do with the slow changing ranges when cold but was solved with the other tranny.
    If it could be fixed by a few O-rings, I'd go with it.
