Transmission vibration 13 speed eaton fuller
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HP510, May 10, 2023.
  1. HP510
    HP510 Bobtail Member
    25
    8
    Sep 4, 2019
    I have a brand new truck about 88k miles and when I put my truck in reverse or 1st gear and let it move in low rpms without accelerating I get a rumble/vibration in the transmission. Is there anything I can do to fix this problem? I have a 13 speed, clutch brake is good, gears go in easily, sometimes have to jam it in while switching gears but it doesn’t grind at all. My biggest concern is the rumble/vibration at low gear on low rpms.
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,723
    16,474
    Jan 18, 2011
    Are you sure it’s in Tranny?
    Not being there and witnessing I can’t say....
    But my gut says ck driveline real closely first
    Good luck
    DUNE-T Thanks this.
  4. HP510
    25
    8
    Sep 4, 2019
    It feels like the tranny but I will check my driveline today. Should I be looking for wobble on my driveline?
  5. HP510
    25
    8
    Sep 4, 2019
    When I hold the clutch in alittle and ride it it stops vibrating that’s why I think it’s tranny
  6. Big Road Skateboard
    6,298
    34,859
    May 2, 2021
    Has the throw out bearing been greased?
    HP510 and Stringb8n Thank this.
  7. Stringb8n
    Stringb8n Road Train Member
    1,633
    2,099
    Sep 27, 2015
    Hold the clutch in a little? Do you have any free travel on the clutch pedal? If not, start with getting the clutch adjusted. It shouldn't be engaging by just barely touching the clutch. Or possibly grease your throw-out bearing. I'd do both if it was me.
    HP510, JB7 and Big Road Skateboard Thank this.
  8. HP510
    25
    8
    Sep 4, 2019
    I adjusted the clutch about a week ago, I have roughly 1 inch and a half of free play on the clutch. I did grease a month ago from the remote grease by the engine but I’m not sure if it’s getting into the throw out bearing. Should I be able to see grease somewhere when I open up the inspection plate?
  9. HP510
    25
    8
    Sep 4, 2019
    I will double check everything tonight
  10. Stringb8n
    1,633
    2,099
    Sep 27, 2015
    Where you adjusted the clutch, up under the truck on the bottom side of the transmission anytime I greased a throw out bearing it was right up in there. You will see a grease cert up in that hole. Unless they have relocated those fittings since the last time I greased one. If there is a remote grease hub where you should be able to grease the throw out bearing at that hub or port, it could be something got kinked or cut where it connects to the throw out bearing.
    HP510 Thanks this.
  11. Diesel Dave
    8,814
    25,767
    Jan 20, 2010
    Hesperia, Ca.
    Sometimes it will rattle/slight vibration when it’s barely moving like idling moving. It would feel like a slight vibration though. My drivetrain specialist said, transmissions never vibrate.
    Rideandrepair and lester Thank this.
