Our fruit farm is expanding and we will have two farms 30 miles apart. We want to transport farm equipment bi-weekly between the farms (tractors, sprayers, mowers, ect...) We want to purchase flatbed or a tractor trailer to move the farm equipment and deliver apples to market during harvest. Currently, we deliver apples to market with an 18 wheeler towing 50,000 pounds to market and a flatbed truck loading 28,000 pounds. To move farm equipment, 10,000 pound tractors and sprayers, we are trying to understand the best solution. We are considering buying:
• 28' Jerrdan 15 ton Industrial Rollback with 20,000 pound towing capacity. During the spray season, we would move tractors with the Rollback and during the harvest we would add a trailer and move apples with it.
OR
• 53' X 102 Sliding Axel Trailer for equipment hauling.
OR
• 53' Unit with Hinged Ramps that tuck in or swing up
Any feedback on a configuration would be appreciated?
Transporting Farm Equipment and Apples
Discussion in 'Ask An Owner Operator' started by bobbyq, Feb 8, 2017.
The wrecker just seems asinine and severely limits your apple hauling capacity and very expensive.
The sliding axle equipment hauler is nice and easy to load, great for picking up dead equipment. But is expensive and heavy and you probable need a wet kit on the tractor.
A step deck with ramps is more then enough to 10K tractors. Spayer? Depends what you got for sprayer. The down side the the step deck is ramps are going to cost you more then you think and it is much easier for an employee to screw up loading crap with ramps.
A cheap flat will work out also if your careful.
As a youngster we used to load equipment up in the field just by backing a flatbed into a ditch and driving the equipment up the dirt ramp. We were cheep and never had an issue.
Obviously you could tote the 10K tractors with just a 1-ton truck and farm trailer. -
Not sure what your going to pay for that trailer. But couldn't you find a cheap old tractor with a cab and get another sprayer? I am assuming that you are using a smaller pull behind sprayer. Also a little confused if you are already hauling with your own 18 wheeler or hiring out.
find a bank/build a dirt ramp @ both locations and just drive your equipment on and off your flatbed.
How often do you need to move the equipment per year?
Or a trailer with a beaver tail/ramp. I also like the idea of a dirt pile for a ramp. You can put them anywhere and they work great.
You could do a flat. And build a berm dock. When I load Humvees , it's a earthen mound with a rail road ties face or concrete face to back into. Them Humvee goes up earth works on to trailer. They do that for steps too.
Ramps would work on step too.Last edited: Feb 11, 2017
You could get a Landoll sliding axle trailer with a pony motor. The trailer new is in the high 70k range with the pony motor. I have the Landoll with a pony motor but it's the trailer with a tail. The Axles slide about 5 ft and the 15 ft tail drops down giving a nice load angle. Either style trailer is nice and I have used both.
