Tri-Axle Vs Dual Tandems - The Ultimate Showdown
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by The3SomeTrailer, Jan 31, 2019.
  1. The3SomeTrailer
    The3SomeTrailer Light Load Member
    63
    13
    Dec 25, 2018
    Lets hear it boys. I want to hear the good, the bad, the ugly, the unknown, the dirty....all of it.
    Stability seems to be a big factor in favor of the tandems. I am going to be pulling only within a 75mile radius of Atlanta, strictly intrastate, non-CDL. Lets save THAT debate for another thread.
    I am strictly trying to determine which of these two, wedge-trailer-axle options will serve me best. Its roughly $1500 more for the dual tandems. More tires. Less axles. From what I gathered, I hear they tandems are more stable and safer if there is a blowout. Can anyone talk to me about that? Anyone had a blowout while loaded with their wedge? What happened? Was it a disaster? This is my biggest fear as far entering the trucking game.
    I really want to hear the guys who know their -ish.
    Pleases, and thank you's.
  3. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    Nothing disastrous happens when a blow happens. Had to many of them on my 6car triaxle trailer.
    I would go with the tandem tire setup, with triaxle setups the tire fight each other while turning sharply and just scrub like an eraser on paper. If your planning to do only local stuff, you'll be turning lots.
  4. The3SomeTrailer
    63
    13
    Dec 25, 2018
    Huge point with the local runs part. Much appreciated. I think I am gonna bite the $1500 bullet and go dual tandem.
    KB3MMX Thanks this.
  5. Kawinige01
    Kawinige01 Heavy Load Member
    864
    1,150
    May 30, 2016
    South Fla
    The 2 axles are usually stronger if not the same rating as the triple.with less wear and tear
    KB3MMX Thanks this.
  6. USMC '74-'78 Semper Fi
    USMC '74-'78 Semper Fi Light Load Member
    134
    133
    Nov 13, 2013
    Mount Union, PA
    For what's its worth, should I buy another trailer, it will not have three axles. Duals with tandems for me. Thanks, PK
    KB3MMX and The3SomeTrailer Thank this.
  7. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    I'm in agreement with the others. I'd only buy a triple axle if it was a smoking deal, or the type of trailer I needed to do the job required 3 axles. A wedge does not fit that category to me..
    I'd also make sure to get the upgrade from 10-14ply tires. 10plys are straight junk in my eyes & caused me nothing but problems. They are so soft they suck up nails like hoover, like to blow apart on the interstate when it's hot out, & almost all (a few are higher) are only speed rated @65mph..
    Another option you may or may not have considered is the super single 17.5". You can run two 10k or 12k axles with only 4 tires like this. 235/75 or 245/70r17.5 18ply rubber rated for 6005lbs & 75mph per tire. Might hold up better in your "high scrub" application since you mentioned running a local 75 mile radius..
  8. The3SomeTrailer
    63
    13
    Dec 25, 2018
    Much appreciated.
    singlescrewshaker Thanks this.
  9. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    I am by no means advocating a 3 single axle over a dual tandem setup, BUT, on some of those you can get (3) 8,000 or 24,000 and still stay under FET, However with a dual tandem you are in most states stuck at 20,000 that extra 4,000 may come in handy, jus saying.
  10. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    Why would a dual tandem be stuck at only 20,000lbs? I can see that, if he were to get tandem 10k's. But what about 12k's, 15k's, & there's even some 16k electric brake axles out there now. As long as it has the minimum 40" spread between axles or whatever why would it be a problem.?
    I have a tandem dual 12k axle mini float stickered @ 24,000lbs (no fet) & sometimes load the axles right up to max. I've had the trailers spread measured once at the Mt. Airy coop SB on I77. Mines 48" so I already knew I was cool..
    Is there something I'm missing..?
    KB3MMX and KANSAS TRANSIT Thank this.
  11. KANSAS TRANSIT
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    Nope you are absolutely correct, I misspoke and was thinking he was comparing a single axle dual at 20,000 vs the trip 8's at 24,000, I think I wrote dual tandem out of habit.
    KB3MMX and singlescrewshaker Thank this.
