Tricks for after onion loas
Discussion in 'Experienced Truckers' Advice' started by jaso37, Mar 15, 2016.
  1. jaso37
    jaso37 Heavy Load Member
    817
    1,384
    Sep 25, 2014
    Just curious to see if there are any tricks some of you might have on descenting a trailer. I just had an onion load had to go to two different washouts. And if you know something for other stinky products that would be helpful too. Thank you in advance for any help
    RMU91 Thanks this.
  3. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Coffee works great for getting the smell out.Lightly sprinkle Coffee all over trailer then let it air out with trl doors open for an hr and sweep out.
    TGUNKEL, crb, RMU91 and 3 others Thank this.
  4. G/MAN
    G/MAN Road Train Member
    7,031
    8,624
    Sep 3, 2010
    Yep, coffee works great!!
    crb, RMU91, Longarm and 1 other person Thank this.
  5. FerrissWheel
    FerrissWheel Road Train Member
    1,997
    5,931
    Dec 23, 2015
    NV
    Coffee is a great trick, make sure the Trl washouts use deoderizer too.
    Leave the doors open as much as possible at night. Or run it with the vent open going down the road. Any thing to air it out.
    In a pinch when you don't have much time, turn the temp all the way down, the cold wet metal smell tends to mask the onion smell some. Of course that depends on how strict the next customer is.
    crb and jaso37 Thank this.
  6. RMU91
    RMU91 Light Load Member
    217
    148
    Jan 3, 2016
    Do that AFTER sprinkling the trailer floor with coffee grounds (do not buy and sprinkle liquid coffee and expect it to work).
    jaso37 and FerrissWheel Thank this.
  7. Sten Bartelson
    Sten Bartelson Bobtail Member
    15
    13
    Dec 19, 2015
    Chorine bomb:eek: Or sulfur choride gas.
    jaso37 Thanks this.
  8. Chinatown
    Chinatown Road Train Member
    76,738
    178,609
    Aug 28, 2011
    Henderson, NV & Orient
    I always used coffee. Sweep it around on the floor to grind it in then leave it until just before arriving at the next shipper.
    Someone left some fish in one trailer and the odor was horrible. Had it washed with scented wash and it still stunk so used coffee which helped a lot, but still terrible. Set the temp at zero degrees and left it that way a few hours and didn't shut it off until arriving at the shipper.
    No smell when I opened the doors for a dry load. They were slow and by the time they put the last pallet on the smell was coming back and the loader noticed it. I told him I didn't smell anything but did notice a smell outside from some other trailer. He bought the story.
    TGUNKEL, jaso37 and FerrissWheel Thank this.
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    I will also say find a good washout that uses some deodorizer. Then park for the night with doors open. Always works for me after onion loads.
    jaso37 Thanks this.
  10. jaso37
    817
    1,384
    Sep 25, 2014
    Thank you everyone. I will buy coffee next time I'm at the store.
  11. jamesthewiseone
    jamesthewiseone Bobtail Member
    13
    19
    Mar 3, 2016
    Texas
    Never had anyone refuse to load me after an onion load, without having a wash out
    jaso37 Thanks this.
