My question is...
If you travel the same highway more than once a day, do you write it down more than once?
Trip Report & Highways Used
Discussion in 'Questions From New Drivers' started by BROKENSPROKET, Apr 6, 2014.
For the same trip? If they just want the highways used, and not a detailed report of your route, you only need to put it down once for each state.
BROKENSPROKET Thanks this. -
Yes, you only have to write them down once between each pair of state lines. Don't forget your odometer readings when crossing state lines either.
Thanks guys. I was told, only once a day per state, no matter how many times you travel it. Just wanted to make sure.
Do you right down a highway you are on for 1/4 of a mile.
For example, coming off the freeway to a truckstop, then right back onto the freeway. Do you write down the highway that the truck stop is on? -
I would think you should.
