Tripac APU Eng Code Help!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Sep 7, 2018.
  1. PE_T
    PE_T Road Train Member
    Eng code appears about 10 seconds after I press the APU button. I have tried turning off/on the APU, reseting it, and checking the fuses, but nothing. I am guessing the problem may be the wiring. What is strange is that my APU was working yesterday, but after 11 hours of driving, I noticed it was already on ENG code.
  3. PE_T
    I should add that the Eng code comes on so fast it won’t even let the APU engine start.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    there is a switch in APU box. Check to see it is working correctly, check to see wires are on place on that switch.
    PE_T Thanks this.
  5. PE_T
    Well, I took it to TK, and the problem was a corroded wire behind the on/off switch inside the APU housing. I need to start inspecting all the wires for corrosion on both my APU and truck. The bill was $500. It’s always hundreds of dollars with those guys. I’m gonna clean all my wires with a wire brush and put some grease on them so hopefully they won’t corrode too easily.
  6. 86scotty
    86scotty Road Train Member
    4,630
    12,602
    Aug 27, 2017
    Appalachia
    I'm chasing a similar problem. Do you mean the corrostion was behind the switch inside the APU itself or inside the control box under bunk?
    Thanks
  7. PE_T
    Inside the APU. There are actually lots of wires. Water seems to find its way inside the APU and mess up the wires, I think.
