Unit runs starts right up. Replaced heater blower glow pin last winter fuel pump is clicking. All fuses are good. I'm thinking it's the pre filter will I need to bleed the lines when I replace it?
Tripac heater blows cold air no smoke from bunk exhausr
Discussion in 'Ask An Owner Operator' started by Stormbk, Nov 5, 2014.
I would try to bleed it before doing anything. Ie cycle it a couple times if that doesn't help it could be the pre filter but most likely it's something else
I'm assuming your taking about the Espar/Airtronic heater? Does the unit run non stop blowing cold air or does it start and stop a number of times?
It runs and stops
Completely plugged not even a dribble
if you put your hand on the pump you should feel it pulsing. If that is happening then the pump is bad. If it's not pulsing then either the pump is bad or broken wire
