Truck ABS, and trailer ABS lights come on and dash lights go out.
Discussion in 'Ask An Owner Operator' started by Rookie2020, Jul 13, 2022.
  1. Rookie2020
    Rookie2020 Bobtail Member
    35
    24
    Sep 22, 2020
    I am an owner operator and new in trucking. I have a 2005 freightliner century, 12.7 L and Detroit 60 series.
    I am driving on the highway and of a sudden the traction control triangle, truck ABS, and trailer ABS lights come on, then out of nowhere all the dashboard lights went out and came back on 3-4 seconds later. This has been happening all night during my 200 miles drive.
    Please, any help, suggestion, or advice will be appreciated.
    Thank you and God bless you all on the road
  3. YumDinger
    YumDinger Light Load Member
    79
    154
    May 5, 2022
  4. Rookie2020
    35
    24
    Sep 22, 2020
    Do you mean the tire or the steering wheel?
    tscottme Thanks this.
  5. gentleroger
    gentleroger Road Train Member
    7,474
    20,335
    Jun 1, 2010
    It could be any number of things - from a bad wheel sensor, or a bad ground, a wire chuffed, or up to a bad ecu/ecm.
    Rookie2020 Thanks this.
  6. tscottme
    tscottme Road Train Member
    he's talking about a sensor that monitors the wheels the tires are mounted on. ABS systems have sensors to detect when one of the rolling wheels stops rolling (skidding) or is rolling at a grossly different rate than the other monitored wheels and then reduces brake pressure to that wheel.
    Rookie2020 and YumDinger Thank this.
  7. tscottme
    It sounds like a sensor or wiring problem. Unless you see some unusual and unexplained wires hanging down there is nothing you can do to fix it. It needs to go to a shop, probably a dealership.
  8. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Before you go to the stealer, take a minute or two to look in the battery box for a loose wire. I've had 3 Centurys and all of them had some really janky factory power feed wires in there that would come loose from time to time. Especially when a previous owner repaired it the last time without using proper heat shrink terminals and the like, and a crappy roadside repair fell off again. While you're in there, replace any cable terminals that have any sign of green cancer and tighten everything up.
    Rookie2020, Siinman and lester Thank this.
  9. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    Loose power/ground wire. I have a 06. Abs light comes on all the time, trailer abs too. If it doesn’t affect any driving it’s just another annoying wire.
  10. AModelCat
    159,388
    The fact you mention the dash reboot itself would steer me toward a power/ground issue with a module, rather than an ABS problem specifically.
    RedForeman and Rookie2020 Thank this.
