Truck Air Filters
Discussion in 'Experienced Truckers' Advice' started by dontruck, Sep 30, 2014.
  1. dontruck
    dontruck Bobtail Member
    Hi guys, what do you do for cleaning air filters?
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Donaldson Good grief you cant type one word.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    cleaning is a bad idea. replace with new. when you try to clean, blow out, e.t.c you loosen dust, dirt particles, that get sucked thru the engine. after taking old filter out wipe inside container with a vary damp cloth, let dry & put in new filter. if you have a foam type filter or another type that IS reusable, than do what the mfr say's, but if it is a paper type disposable, throw it out after it's full use & get new.
  5. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    Considering most paper air filters will last 200-300k miles before needing changed I'd just change it.
  6. Vito
    Vito Heavy Load Member
    878
    950
    Jun 4, 2012
    North Carolina
    Well if you're trying to save some money you could extend the life of your filter by using a lawn blower. I'm not really of the opinion that leaving a dirty filter in there is better than taking it out and blowing it. And I'm not really agreeing that after blowing it out really well, it is somehow going to be worse than if you hadn't touched it. You just have to be careful not to break the paper by blowing too forcefully. I've cleaned air filters like this and have had a lot of success. Again, this is if you're really strapped for cash, because...
    ... obviously the best method is to replace it.
  7. MysticHZ
    MysticHZ Road Train Member
    5,876
    5,678
    May 28, 2010
    At $25 a filter, I just replace it every 90 days ...
  8. mattbnr
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    That's a lot of wasted money over the life of a truck. A filter will last at least a year if not more on highway use. Unless your driving around dirt filled construction sites there's no need to change it that often.
  9. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    i give up.where do you personally purchase a $25.00 air filter? $65.00+/- is the average,at least those that i have personally bought.
    double yellow Thanks this.
  10. x#1
    1,773
    1,104
    Dec 24, 2009
    ever operate in severe conditions? I think not judging by your reply. Not being a smartarse,but even under <less than severe conditions,an air filter will not last 250,000 miles unless it is of the washable type.why would you want to use an air filter w/that many miles on it? if you pull it out and dirt can be knocked off of it w/out blowing air thru it,it is time to replace it.I generally blow those i use out 3 times max. I am off road more than most but still,you are talking about the next most important item on your engine next to the oil filter.
    250,00-300,000 miles. wow.that is a lot of miles on the same air filter. my opinion only.
  11. MysticHZ
    5,876
    5,678
    May 28, 2010
    Company shop ...
