truck at shop
Discussion in 'Ask An Owner Operator' started by MackRookie, Jan 1, 2018.
  1. MackRookie
    MackRookie Light Load Member
    193
    25
    Nov 30, 2017
    Canada
    Dropped truck at mechanic. I noted my kms and it' 100km over . I'm sure someone used it for local shift.. what to do?
  3. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Is it your truck or a company truck? Is it a company shop or independent?
    If it is a company truck dropped at a company shop, they can do as they please with their truck. Even if you're a L/P driver, the company has more liberty with "your" truck than if you actually own it.
    Assuming, however, that it IS your truck (thus posting in the O/O section) and a private shop, there really aren't too many reasons for the odometer to have changed by that much. Have you asked the shop? That would be your first step. Depending upon what was done, perhaps they needed to run it up the road to another facility? For example, change the kingpins or replace tie rod ends and you ought to have an alignment done...and if the shop that did the mechanical work doesn't do alignments and the nearest/best alignment shop is 50 km up the road, the round trip will add a few km's to the odometer. There may be a perfectly good explaination...but you won't know unless you ask.
    TallJoe and Justrucking2 Thank this.
  4. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    An hour test drive? Depends on what was done...
    Oxbow and TallJoe Thank this.
  5. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    belts and coolant hoses. that' it and it' my truck.
  6. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    I'm owner and it was private shop. I told him hey u used my truck for a day shift. He said oh I moved a trailer around in the shop. I said that' fine but that' not why my truck over 100km .. He said he will find out who took the truck
  7. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I'm guessing whoever did may not have a job for long, then.
    And I wouldn't be OK with any shop using my truck to move a trailer around, unless it was there for 5th wheel related issues and it was part of the road test. If the move is not directly related to something the truck is at the shop to have done, then the move should not happen.
    TallJoe and Blackshack46 Thank this.
  8. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    That's why I'm so pissed don't know what to do.
  9. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I'd demand a credit on the bill to compensate for the use of the truck. What's the federal rate for automobile use up there? (Assuming Canada, as you're giving distance in km). Here, it was 53.5 cents per mile in 2017. That should be the MINIMUM that gets knocked off your bill. What's your cost per mile (or km)? I'd say that would be a fair top end, since that would also include driver pay and such which really isn't out of your pocket in this instance...so I doubt he'd be inclined to go beyond that. I'd also stress that this sort of thing is unacceptable. At the very least, this amount needs to cover the fuel and other wear & tear items (tires, brakes, etc.) used.
    MackRookie Thanks this.
  10. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Really,, might see your truck on the news stealing a load of whisky. Get your alibi straight.
  11. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    I wonder if I should tell him ima call the cops and the truck was taken from the yard.
