Truck cabin vibration at 30mph, stops after
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SFLTRKBIZ, Mar 17, 2014.
  1. SFLTRKBIZ
    SFLTRKBIZ Light Load Member
    60
    24
    Sep 30, 2012
    Hello everyone, the truck is a 2005 volvo 670. It has a slight cabin vibration at 30 mpg, not felt in the steering wheel though. After 30 mph it smooths out. I would think its a tire balance issue or alignment. What do you guys think?
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Yeah sounds like tire or drive line vibration
  4. tk40176
    tk40176 Light Load Member
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Have your U-Joints checked.
  5. 4vmach1
    4vmach1 Light Load Member
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    U-joints or maybe the drives haft is out of phase if you had to remover the drive shaft for any recent work.
  6. Heavyd
    Heavyd Road Train Member
    7,770
    6,210
    Feb 4, 2009
    Ok, alignments never cause or fix vibrations. Never have an alignment done to try to repair a vibration, you are just wasting your money. Volvo likes to use maintenance free, or grease-less u-joints and slip joints. These will dry up after a while and start to seize. The only way to check is to disassemble and try to move by hand.
  7. Dasologa
    Dasologa Bobtail Member
    7
    Mar 22, 2014
    i would lean toward U-joint too, or wheel balance, are you running wheel balancer ? or did you had the tyre balanced when mounted on rim ? if not i would check on that, or maybe snow accumulation inside the rims, seen that a few times, rims is packed full of snow and ice, and it makes the wheels go off-balance ......
  8. Lucas379
    Lucas379 Bobtail Member
    I have to agree with 4vmach1
  9. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    A drive line problem will usually change with acceleration.
  10. rank
    rank Road Train Member
    9,918
    113,503
    Feb 11, 2010
    Bad injectors.
    :smt064
  11. Dasologa
    7
    Mar 22, 2014
    i would tend to agree for bad injectors....
