Truck For DMV CDL Driving Portion In Virginia
Discussion in 'Questions From New Drivers' started by ALilly, May 7, 2015.
  1. ALilly
    ALilly Bobtail Member
    Hi
    My Husband Is Currently Looking Into The Trucking Industry And He Is Trying To Locate Someone To Lease/Rent A Truck For The DMV Road Test He Has Experience Driving Them But We Do Not Know Of Anyone Who Will Rent A Truck For The Test
    If Anyone Has Any Information Or Willing To Rent A Truck For His Test Please Send Me A Message
    We Are Located In Wytheville Area/Wythe County
    Thank You
    Mrs A. Lilly
  3. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    This comes up fairly often and never happens. He will need to go to a school.
  4. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    ther are SOME(read not many) schools/comm college that you can rent truck from them.
  5. ALilly
    thank you damutt for the information i'll check with the local comm college as well :)
    i understand most truckers do not want to rent there truck to a stranger it's hard to trust anyone these days.. and he has looked into trucking schools the cheapest one i cant remember what he said it was called wanted $3500 down in advance and the man he spoke to said it only has a 10% success rate on people actually passing the course it's hard to think of losing all that money for a school we are newly weds and i'm sure you know it's hard when you first start building you life I Will take any and all advice given to me
  6. TripleSix
    129,327
    They only have a 10% success rate and want $3500 down? Sounds like your husband found the worst CDL instructors in North America.
  7. StoneSSD
    StoneSSD Bobtail Member
    47
    66
    Dec 9, 2013
    Richmond VA
    Virginia recently decided to rewrite the CDL evaluation process and put it in place 1 July 2015. It seems certain offices didn't get the memo and are in "make it up as you go mode."
    Just as an FYI
    The Woodbridge DMV has an 80% or above failure rate for first time test takers. Of 32 persons only 1 passed.
    The evaluators seem to have widely varying opinions of what constitutes line encroachment (1' or 3' or some other unspecified amount)
    On evaluator will state a Class A vehicle without hazmat is required to use the 4 way flashers 200' before a rail crossing (this is only applicable to passenger busses per CDL manual)
    Another evaluator believes Z-spring is an incorrect term when discussing suspension components on the PTI.
    I would like to know how an evaluator believes an axle grease seal "oil level" can be checked and filled when low...
    IMO the Woodbridge DMV is hit or miss - with more miss than hit. The lot is at a very weird angle and because of this a blind side parallel parking task can be very difficult because you will roll forward if not quick on the clutch and several evaluators will call any forward movement a pull up with no exception.
    They will not tell you that you must pull completely through the cones either, unless you ask for specific pronouncement of the completion point - and what constitutes a successful straight-back followed by pull up.
