Truck Hops In Reverse
Discussion in 'Questions From New Drivers' started by camaron32, Feb 23, 2012.
  1. camaron32
    camaron32 Light Load Member
    81
    6
    May 31, 2010
    Rosemount, Minnesota
    When backing up I ride the clutch a bit so I can control the speed of the truck. Sometimes this results in a very violent hop by the truck. Any suggestions on how I can stop this?
  3. JohnCooperWorks
    JohnCooperWorks Light Load Member
    179
    31
    Sep 3, 2011
    Orlando
    apply a lite amount of brake when sliding the clutch.
  4. Tanker Hauler
    Tanker Hauler Light Load Member
    123
    36
    Sep 1, 2010
    New England
    Don't "ride" the clutch.
    Jfaulk99 Thanks this.
  5. Tanker Hauler
    123
    36
    Sep 1, 2010
    New England
    Your probably turning too sharp.
  6. Green Machine
    Green Machine Medium Load Member
    623
    175
    Jul 23, 2009
    You can control your speed better with releasing the clutch all the way and then slight braking. You shouldn't have to "ride" the clutch.
  7. RockinChair
    RockinChair Road Train Member
    4,973
    12,438
    Feb 19, 2012
    CC, TX
    How is it that idling in reverse is causing the truck to go too fast? Are you backing down a grade, or do you have a really high (numerically low) axle ratio?
    First off, I assume you have the transmission in low range, and that you're idling the whole time (not giving it any throttle).
    Riding the clutch is not allowing engine braking to do its job. Let the clutch all the way out, then use light pressure on the service brakes to slow down. Plus, you could be damaging the clutch.
  8. sidepocket
    sidepocket Light Load Member
    268
    88
    Mar 1, 2011
    louisa, va
    Driveline lash is whats happening. And yes its kinda because youre riding the clutch.
  9. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    is it with a heavy load? same thing happened to me when id do that. just release the clutch and use just the brake like mentioned above
    rolloverdude Thanks this.
  10. wis bang
    wis bang Road Train Member
    3,364
    3,950
    Jan 12, 2011
    Levittown, PA
    Driveline deflection, U-joints do not always transmit power at the same speed. With the clutch out the center hub dampens this but slipping the clutch means you are constantly applying torque and keep the center hub from doing it's job...which is absorbing the tiny im-balances from crankshaft rotation, etc. The applied torque of the slipping clutch keeps the center hub locked.
    The more a U-joint bends the slower the other half turns and this 'lash' is one of the forces the clutch center hub absorbs.
    Since most tractors still use dual clutch plates, you are pushing against two center hubs.
    I learned this at 16 trying to back a small 6 wheel wrecker over a curb...the impact would cause my foot to make the clutch dis-engage & the boss yelled to get my foot off the clutch and drive the truck up over the curb...:sign7:
  11. freedhardwoods
    freedhardwoods Light Load Member
    244
    127
    Feb 4, 2011
    SW IN
    Explain exactly what you are doing when you ride the clutch. Are you pulling closed tandems or a spread axle?
