Truck is "belching" white smoke.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gekko1323, Jun 5, 2023.
  1. gekko1323
    gekko1323 Road Train Member
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    Good afternoon folks. Every once in awhile, my truck starts to growl or rumble from deep within her bowels, shake a little, then "belches" white/light gray smoke out of her stacks. She's been doing this since I got her. Sometimes she'll go weeks without doing it, other times (like yesterday) she'll do it several times a day.
    I have yet to add a drop of oil in her (besides regular changes at 13,000 miles). I get a sample done by the people in Ft. Wayne every change, and they come back stellar. Report says I can go to 16,000 between changes if I want. I also had her overheads done a month ago.
    Can this have anything to do with the fact that she's "neutered"? It's a DD S-60, 14L, DDEC VI.
    Looking forward to your insights.
  3. Lazer
    Lazer Road Train Member
    1,830
    2,940
    Jan 22, 2017
    Is the engine using any coolant?
    gekko1323 Thanks this.
  4. 77fib77
    77fib77 Road Train Member
    11,373
    74,071
    Jul 7, 2010
    St Louis
    Injector? Idk. It could be the harness too. Mine does the same thing once in three days or once in two weeks. Never figured it out. DD15.
  5. gekko1323
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    No. I've NEVER had to add coolant since I bought her.
  6. gekko1323
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    Yours rumbles and shakes also before belching?
  7. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    The DDEC VI was plagued with injector issues ever since its inception. Basically the same injector as a Volvo D13, and we all know that story. I am obviously only guessing at this and taking into account that your "tune" and equipment mods are correct.
    D.Tibbitt, Last Call and gekko1323 Thank this.
  8. gekko1323
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    That would probably explain the weak power on any little hill? I thought doing the overheads might have solved this but no.
  9. Last Call
    Last Call Road Train Member
    7,568
    45,910
    Mar 15, 2021
    This ^^^^^ I would maybe think you might a injector cup that might be leaking also
    QUALITYTRUCK and gekko1323 Thank this.
  10. gekko1323
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
    I guess the injectors are next on the list to get checked out then.
  11. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    Injector cups are easy to change when injectors are removed. Cups are stainless steel, so weak point is cup o rings.They just "unscrew" from head. You will need proper cup removal tool (amazon under $100) If ordering, make sure you get correct one. DDEC V used similar tool. Just different enough to not work on DDEC VI.
    D.Tibbitt, gekko1323 and Oxbow Thank this.
