Truck losing air pressure when parked,can’t find the leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dadetrucking305, Apr 27, 2021.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Earlier today I was going to get my first load of sand and I drove unto the scale/silo and set my brakes.A minute or two into the loading process the low air light comes on.I finish getting loaded and drive over to the area where we can roll our tarps up and started looking for a leak with the truck off but found nothing.I ended up idling up t’ill I’m at 90psi and start driving down the rural road leading away from the sand plant.The highest PSI I got was 100.When I made it to the site I got in line behind a bunch of trucks and every time a truck moved forward I released the brakes and the low air light would come on.Just finished unloading and pulled off the site to an empty site down the road and checked everything again with the truck off.Also with the wheels chocked and brakes released.And with the key in the on position and found nothing.What could be causing this?
  3. Flat Earth Trucker
    4,138
    15,511
    Nov 19, 2018
    If it's an automatic transmission, then the transmission air lines might be your culprit.
    The usual suspects would be the air hose cluster on the firewall. Those plastic fittings are nobody's friend.
    In my experience, losing air from a hose near the dog bone was common. Apply soapy water to those lines and give a look see.
    Dadetrucking305 Thanks this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    What year and make of truck and which engine? Could be turbo actuator. That would only leak after a certain amount of air built up around 80 ish + or - and only with the truck running.
  5. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    2003 International 9900 with 2004 Cummins CM870.A mechanic looked at it every put his hand over the compressor outlet and he was able to hold it easily so he says it’s the compressor.
    Smellfunny Thanks this.
  6. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    Make sure if you put a new compressor on to remove the fitting at air dryer and make sure it is not clogged up at the screen in the air dryer.
  7. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    I just saw this,but I installed the compressor and a new governor and it all seems to be working fine now.
