Truck Minor Vibration over 70 MPH?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jun 7, 2019.
  1. PE_T
    PE_T Road Train Member
    Sometimes when going down a hill at 70 MPH or higher, I sense this minor vibration. I’m in the process of changing my leveling valve rod/link, but are there other components that could be causing this? The leveling valve itself? I don’t think it has ever been changed. This is on a 2014 Freightliner Cascadia DD15 with 745k miles.
    It vibrates for one second, then it stops, and the cycle continues. Sometimes there is no vibration. I’m thinking the road itself may have something to do with it as well (asphalt vs concrete).
    Rideandrepair Thanks this.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    You say the vibration is when coming down hill, have you thought it may be linked to your Jakes somehow.
    Rideandrepair and PE_T Thank this.
  4. PE_T
    For this vibration, my jakes were not turned on.
  5. starmac
    starmac Road Train Member
    6,639
    12,529
    Apr 11, 2019
    Fairbanks Ak
    Possible slop in the drivelines, maybe slip yokes.
  6. RustyBolt
    RustyBolt Road Train Member
    2,081
    3,335
    Feb 21, 2015
    Bement, IL
    Not sure how one associates a vibration with a leveling valve. Care to elaborate on the thought process behind this?
  7. PE_T
    I’m not sure either, but I’ve heard some mention it.
  8. Goodysnap
    Goodysnap Road Train Member
    3,812
    9,296
    Jul 12, 2017
    Suspension ride height is one of the most common areas of driveline vibration issues. If the ride height is high or low from spec the driveshafts and ujoint operating angles can be extreme and will cause a vibration that can come and go upon accell and decell. This type of vibration will usually be felt in your feet and it your seat, maybe the shifter as well.
    The leveling valve is the valve the maintains the suspension ride height and is most often the adjustment point to set the desired ride height level. This is something that is easy to check and set and is always first on the list to check when troubleshooting a vibration complaint.
  9. frito bandito
    frito bandito Light Load Member
    124
    457
    May 31, 2019
    I'd start with the easy stuff first: tires(inflation, balance, out of round, flat spots) and then the shocks and then the alignment.
    Good Luck!
  10. Rideandrepair
    17,600
    56,990
    Aug 8, 2015
    Don’t forget wheels, check for bent rim, by spinning wheel against a stationary object. Aluminum’s can get distorted easier and quicker than you’d think. Especially steers.
    PE_T and frito bandito Thank this.
  11. Rideandrepair
    17,600
    56,990
    Aug 8, 2015
    I’m gonna guess it’s probably on or more of the wheel balances. Spin balancing being set on a machine, doesn’t mean it stays balanced at all speeds.I don’t know about Trucks, but high speed on the Car balancing with a machine is done when other techniques don’t work. never seen if done on a Truck only Cars.Centramatics or equal, maybe? Otherwise it may be one of the driveshafts, since only downhill. A loose u- joint or not enough angle ( set too low ) causing vibrations. Drive shafts aren’t balanced as good as they can be, from the factory.
    PE_T Thanks this.
