truck missing need help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by homesick, Apr 30, 2009.
  1. homesick
    homesick Light Load Member
    161
    8
    Nov 26, 2007
    memphis,tn
    my truck is missing and i cant figure out what it is.the truck hesites and misses once it gets up to speed it runs smooth.the shop has hooked a computerup and road tested it and thinks it is a injector but cant tell for sure.will a dyno show which injectors are bad and what does a dyno usually cost.the truck is a 99 fld with n14 and 10 speed auto
  3. Heavyd
    Heavyd Road Train Member
    7,815
    6,267
    Feb 4, 2009
    Start with the simple things first. Have the shop install a sight-glass or clear fuel line at the inlet of the pump, or filter housing and see if the fuel has a lot of air bubbles. A good culprit of your symptoms is the engine sucking some air from a leaking fuel line on the suction side.
  4. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    u can also bypass the ecm cooling plate with a union. have seen a few of of those sucking air thier . also check your fuel line t's or shut offs above the rear of the transmission for fuel leaks. a shop with a cummins computer should be able to run cylinder cut out and the computer will show if a injector is bad or not. and i take it u have no check engine light?
  5. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
  6. FYDA FREIGHTLINER CINCY
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    bypass the ecm cooling plate first..
  7. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    i have no idea what you are talking about
  8. Bigray
    Bigray Road Train Member
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    the mechanic will, take the truck to a dealership or cummins guy.
  9. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    what will bypassing it do
  10. Baack
    Baack Road Train Member
    15,294
    10,174
    May 24, 2007
    Wisconsin
    Where is the last time you remember seeing it LOL
    Every time I see this thread title I keep thinking you lost something:biggrin_25519:
    Freebird135 Thanks this.
  11. Heavyd
    7,815
    6,267
    Feb 4, 2009
    By passing those parts will help troubleshoot your problem. They will bypass temporarily to help diagnose.
