Truck Pulls Right - Process of Elimination?
Discussion in 'Experienced Truckers' Advice' started by OhNoTerry, Jan 4, 2025.
  1. OhNoTerry
    OhNoTerry Medium Load Member
    316
    475
    May 22, 2021
    Truck is a '23 W9 with AG400L suspension, 13.2k ultrawide steer axle with 160k miles. I haul 105k gross, with a 50k loaded trailer. 8 axle set up, 4 on truck with steerable drop, and 4 on trailer.
    Trying to get some thoughts on the direction I should be going with finding out the cause of my issue. The truck pulls to the right. I got the trailer (tanker) aligned 3 months ago, checked king pins on my rig THEN got an alignment done. I drove the truck after and the pulling got worse, so now I'm swapping steer tires to see if I can possibly counteract the wear they've experienced with the misalignment.
    I had a mechanic notice my truck sags to the pass. side, but he was doubtful that a truck this young could have a leaf spring pack go bad on the steer axle so soon. What other areas could I look to that could explain my truck wanting to pull passenger side? I have noticed the driver inner side of my 5th wheel near the king pin hole will remove grease and show bare metal more often than any other part of the plate. Could this be a sign of an imbalance in my suspension? Leveling arm not working? Bad bushings? Bad steer axle springs?
    Any help would be much appreciated!
  3. Long FLD
    Long FLD Road Train Member
    12,887
    53,990
    Mar 4, 2015
    Find a level piece of concrete and start measuring. See if the measurement from the bottom of your frame rail to the ground is the same on the front corners. If it is the same then that eliminates front springs.
    Does it pull to the right loaded and empty? If something is wonky with your lift axle valve and it’s putting unequal pressure in the bags that would cause an issue.
    Most of the time when a truck pulls one way or the other the issue is back in your drive axles.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Easiest to measure the highest point of fender to ground. If one side sits lower. It's sagging.
    I drive the same axles. My loads are 60k. Load Weight at 100k. My 5th wheel also makes the most contact at the inner portion. It's the only area i lube these days. Using Lucas and not lube grease.
    If the wheel is dry. It can cause the trailer to offtrack slightly. according to others on this forum.
    Steer tire pull. If it pulls the other way with a rotation it's the tire. All tires pumped up? Any worn bushings in the drive suspension components.
    The trailer was aligned but have you actually looked at the alignment to verify front and rear are straight with each other. On both sides. Easy to do with my side dump trailer. Not so easy on most other trailers.
    What makes you say it's pulling? Does the truck actually pull or are you just thinking it's pulling because the steering wheel might be crooked?
    Not trying to be offensive but some people think that since the steering wheel is crooked. It's pulling. When it's not. It's just not straight.
    beastr123 Thanks this.
  5. OhNoTerry
    316
    475
    May 22, 2021
    Tires are good, rear bushings can be checked. When I say pull, I can hug the dashed lines to my driver side and end up on the rumble strips to my passenger side within 3-5 seconds. Will still pull passenger side if the road I’m on is leaning driver side, just takes a little longer.
    snowwy Thanks this.
  6. drh72
    drh72 Light Load Member
    176
    302
    Aug 19, 2012
    Northeast Minnesota
    I had a similar problem twice over the years. The first time, after many suspension inspections and two alignments, it ended up being a bad steer tire. After exhausting every possible issue it could be, we ended up putting a new set of steers on and the issue went away. If a bad steer tire is your problem it should show itself when you rotate them.
    The second time we installed new rubber on both the steers and drives along with a 3 axle alignment. The new alignment was way off and they had to redo it, which corrected the issue.
    BlackjackCo and OhNoTerry Thank this.
  7. Ridgeline
    22,725
    123,411
    Stop messing around, go to a good shop, have a three-axle alignment, had the fifth wheel checked. Also, ask the shop to see if the axle or frame is bent. I would think MD Alignment shop would help, there are two or three that do a great job.
    OhNoTerry and wis bang Thank this.
  8. brian991219
    brian991219 Road Train Member
    3,023
    6,202
    Aug 10, 2013
    Lords Valley, PA
    Don't discount the sagging just because the truck is new. It doesn't need to be worn out to sag or have a different height. We have had brand new chassis come in from Peterbilt with mismatched spring packs, giving a noticable difference in height from left to right side in the front.
    OhNoTerry and Vampire Thank this.
  9. wis bang
    wis bang Road Train Member
    3,455
    4,099
    Jan 12, 2011
    Levittown, PA
    The three axle alignment should start by double checking spring packs and bushings, etc., as well as the tire tread condition before starting to align anything. Don't discount a cracked spring leaf coupled with the other axles being miss-aligned perhaps from that side striking something. Depending on what is miss-aligned, the steering tires may wear quickly too.
    brian991219 and Vampire Thank this.
  10. Long FLD
    12,887
    53,990
    Mar 4, 2015
    Also check the bushings and alignment on your lift axle. That’s why I asked if it pulls all the time or only when loaded. Watson-Chalin were notorious for eating linkage bushings. Not sure what brand you have on your truck.
  11. OhNoTerry
    316
    475
    May 22, 2021
    It exists with the drop axle in the air, but it reduced when the drop is down. I'm about 12.7k empty on the steer with the drop up, about 9.8k when I have the drop down. Running a Ridewell 13.2 steerable drop.
