Not driving (yet) so I thank you in advance for your patience.
Since it has been a long time since I drove I have a couple of questions.
I recently stopped at a truck stop and noticed the big "air duct" things which I assume are what you are calling the APU.
I have also read several places about "length" of time you can idle.
So......here are a few questions and again I thank you for your patience and understanding!
1. Do MOST companies have these units on their OTR trucks?
2. I am going to guess there is a cost to use these. What is the cost?
3. Are you charged by the hour or is the cost for a 10 hour period?
4. Since I see many trucks in the "lot" I am assuming the availability of these units would be limited?
5. What do you do if one is not available...or your truck is not equiped for them?
6. How long can you idle?
Thanks for anyone who is willing to provide answers.
Be safe out there!![]()
Truck questions
Discussion in 'Questions From New Drivers' started by Mo. Fat Boy, Jul 26, 2008.
The "big air duct things" are IdleAire . Their future is uncertain because the company was recently auctioned off after filing bankruptcy . I think they were charging close to $2 an hour . There is a slot on the window unit to swipe a credit card . Many fleets had contracts and the fuel card can be swiped . There is no minimum usage . APU stands for auxiliary power unit . It's rigged to the tractor similar to a generator on a motorhome . It provides more economical heat and a/c.
APU is, as he said, and Auxialary Power Unit. Usually this means some form of generator, though I have heard of an all-electric system. The idea is to power the truck's A/C or Heating system to keep the driver moderately comfortable in adverse conditions. Some provide enough juice to power additional 115V outlets.
Many states and locales are enacting and enforcing idling laws. Depending on where you are, you can be limited to as little as 5 minutes of idling time. Tickets and fines can ensue, and they can be substantial. Problem is, if you don't have an APU you pretty much HAVE to idle to keep the cab comfortable... ###### if you do, ###### if you don't. -
Ok, my 2 cent question. So in anti-idling areas, gas or diesel powered generators are okay?
