Truck rear driver side tire wont spin!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by classic.n14, Jan 12, 2016.
  1. classic.n14
    classic.n14 Bobtail Member
    6
    Jan 12, 2016
    So Truck has been parked for a week. It did this on the weekend. But after driving around for a bit in the lot it started turning. But its cold again. And when I drove it around the yard the rear tires were spinning but the drivers side front rear tires wont turn over. Just wondering how i can get it to move??
    Thank you!!!
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Are you trying to say they won't roll?
    Most common thing is freezing so bang on the drum with the wheels chocked and the brakes released.
    Second most common is a bad break can.
    Third and the worst is either a cammed over brake or bad wheel bearings.
    americanmadetrucker and josh polk Thank this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    A lot of trucks now a days gave no Lube slack adjusters and s-cams. However it's not no Lube forever.
    If yours is like this it maybe that the s-cams are seizing. If it's not too late, you'll find a hex head set screw on the s-cam tube that maybe hiding under a label, a grease zerk just screws right into the same hole after removing the set screw and grease away.
  5. AModelCat
    154,787
    I've actually seen a truck where all 6 drive axle slack adjuster clevis pins seized up. 1 so bad that the wheel wouldn't release, the other 5 just dragged a lot. I would say its more likely the drum has frozen.
  6. josh polk
    josh polk Light Load Member
    142
    64
    Dec 20, 2015
    Bowie TX
    Just advice u don't won't to ever drive a truck or drag a trailer if all the wheels are not turning I'm sure u seen what it did to the tires
    Only other thing I can thank of is
    Are the brake pads good on that axel ?could b wore out pads and its trying to cam over on u
    I myself any truck I get in soon as I release the brakes I stick it in reverse ease off the cluch and roll back about a foot most of the time if u got a brake stuck this will make it un stick but not always
    Just remember if u ease off the cluch and the truck doesn't move don't force it cause more than likely ur going to tear up something
    Many blessings to u hope
  7. Chris50
    Chris50 Medium Load Member
    346
    215
    Jun 21, 2010
    Florida
    Had mine do this after sitting here in Florida with 100% humidity and lots of rain. One brake was rusted stuck. Try going in reverse that has worked for me and also in/out a few times on the tractor brake knob.
  8. classic.n14
    6
    Jan 12, 2016
    Got it moving.. put some alcohol in through the air compressor. Hammered the brake drum a bit and it did the trick. It was too cold I guess along with starting the truck I should move it too. Thanks for everyones input.
    americanmadetrucker Thanks this.
  9. Dashmegan1
    Dashmegan1 Bobtail Member
    Had my 2018 volvo Automatic day cab just sitting here park in Florida for 1month with 100% humidity and lots of rain. Now my passenger front tire is not spinning but all the other tires are spinning. What cause this to happen?
  10. bumper Jack
    bumper Jack Heavy Load Member
    887
    4,410
    Dec 5, 2021
    Drum rusted to the shoe. Beat it with a hammer with the brakes released and it will pop loose. Chock the wheels first. Hate to see you on cdl life
    Concorde Thanks this.
  11. Concorde
    Concorde Road Train Member
    4,361
    15,524
    Jun 29, 2016
    West Melbourne Florida
    Yes, it’s rusted to the shoe.
    This happens when you park in dirt or especially on grass. I’ve been through it once before and it’s a pain in the butt.
    The other problem you’ll encounter parked on dirt/grass in Florida is ants. They will infest your truck.
    bumper Jack Thanks this.
