Truck shuts off 15 seconds after staring engine???
Discussion in 'Ask An Owner Operator' started by Winter Fox, Jun 8, 2019.
  1. Winter Fox
    Winter Fox Bobtail Member
    27
    6
    Nov 19, 2018
    Hi there, I have major issue with my truck that nobody seems to figure out why. It started two days ago my truck shuts off 15 seconds after starting the engine. Happened to me on the road and I had to pull to the shoulder. First thing I did is replace the fuel filters but it wasn’t that. Then I had to tow the truck 5 miles to Petro truck stop in Scranton PA. Towing alone cost me $ 568.00
    At Petro mechanic check it out and was sure that it was the fuel pump. I called Cleveland brothers down the road and got the fuel pump. Fuel pump was replaced but it wasn’t that. Now they have been on it for two days trying to figure it out with no positive results. I’m in dire need here running out of options. Any suggestions would be greatly appreciated. Truck is Freightliner Columbia 2004 with C15 Cat single turbo engine.
    77fib77 Thanks this.
  3. JonJon78
    JonJon78 Road Train Member
    7,160
    39,549
    Jul 1, 2018
    First thing I would do is get it to a real mechanic not a Petro parts changer.
    Opendeckin, 12 ga, AModelCat and 2 others Thank this.
  4. Espressolane
    17,563
    107,655
    Run and get the diagnostic codes from the ECM.
    See what it has stored.
    Then do some basic troubleshooting
    Fuel or wire.
    magoo68 Thanks this.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Go to a CAT house that is a simple engine to diagnose .. If it’s getting fuel then it’s something like a crankshaft position sensor , power to ecm or even key switch .. A competent mechanic will find issue PS if it’s power to ecm sometimes it doesn’t register a code because it thinks key was turned off
    Opendeckin and baha Thank this.
  6. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Probably not your case(with everyone looking it over)...but,I had a truck that dobe that.Was simply the coolant level Too Low for the coolant sensor to keep a signal.2 quarts of antifreeze and it was good to go.
  7. OldeSkool
    OldeSkool Road Train Member
    1,724
    4,942
    Jul 17, 2018
    New Hampshire
    My Century does that. Won't run if its very low just starts then dies after a bit.
    Opendeckin and BUMBACLADWAR Thank this.
  8. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    My first thought also, if not that , then one of the other sensors.
    BUMBACLADWAR and OldeSkool Thank this.
  9. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Cat eng like you have in your truck has a crank cam speed sensor that goes in head behind air comp that will go bad and Eng will not run and not give a code sorry i did see this sooner buy it and put it in
  10. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    low coolant sensor is a strong possibility
    BUMBACLADWAR Thanks this.
  11. 77fib77
    77fib77 Road Train Member
    10,638
    66,993
    Jul 7, 2010
    St Louis
    Mom. He broke it
