Truck Soap
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ChiiKing, Feb 14, 2012.
  1. ChiiKing
    ChiiKing Bobtail Member
    34
    12
    Oct 24, 2010
    Chicago, IL
    I absolutely love going to Blue Beacon to get my rigs washed, but obviously need to cut cost again and was wondering what type of soap do you guys prefer? I've bought all the generic types of soap and nothing gets my truck clean like Blue Beacon does, I know they use some type of acid also.
    I've searched the net and haven't found anything yet, any advice would be greatly appreciated.
    Thanks!!
  3. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    Are you washing with a brush or just soap/water under pressure?
  4. JDP
    JDP Medium Load Member
    377
    404
    Sep 25, 2011
    Dubuque, IA
    Zep-o-shine for your painted surfaces and any high PH acid mix will do the trick on your aluminum, I think Zep's product is Aluma-a-brite. I have an account with Zep, you pay a lot but I haven't found a better product. Like I said more expensive but expecially their acid requires a lot less elbow grease to get a great end product
    Mommas_money_maker and ChiiKing Thank this.
  5. ChiiKing
    34
    12
    Oct 24, 2010
    Chicago, IL
    Water Pressure washer and a Brush
  6. ChiiKing
    34
    12
    Oct 24, 2010
    Chicago, IL
    JDP your the man! I appreciate it
  7. Licensed to kill
    830
    2,434
    Dec 31, 2010
    Alberta
    High PH is basic, low PH is acidic. When washing with a brush, the best I've found is just plain old sunlight dishsoap. Power wash the big stuff off, 5 gallon pail of water with sunlight and go at it with the brush. Stuff works great and is cheap in 6L jugs from costco.
  8. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    My son uses some purple stuff he buys from the local pressure washer dealer... washes and degreases everything on the truck and does a good job.
  9. JDP
    377
    404
    Sep 25, 2011
    Dubuque, IA
    My bad, I always seem to get that kind of stuff mixed up. :biggrin_25514:
    Anyways, if you end up getting a gallon of Zep-o-shine there is a trick to it. Like many other soaps they claim to leave a finish that feels freshly waxed, it actually works if when rinsing you use a low pressure stream of water and gently rinse it, like a hose without a nozzle on it. Getting tired of turning the water on and off continually, I rigged up a hose valve that fit on the end of the hose with a short 3" section of hose on the end for a "nozzle" that mimicked the flow of the hose.
    The Zep-o-shine is also a PH balancer.
    ChiiKing Thanks this.
  10. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    I use Meguiars NXT Soap with a splash of Zep Tint Window Cleaner, DON'T use dish soap, it will strip any wax you have on the vehicle.
    07-379Pete and Kansas Thank this.
  11. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Agreed, dish soap is way to harsh for use on paint. Will dry it out in a hurry.
