Truck starts, but no instruments and throttle isn't working.
Discussion in 'Volvo Forum' started by Lspilot82, Mar 10, 2019.
  1. Lspilot82
    Lspilot82 Light Load Member
    226
    88
    Aug 8, 2010
    So, I just put new batteries in my 06 Volvo ISX Cummins, and when I start it the instrument cluster doesn't cycle, however it will start. When it starts non of my instruments are working, nor is my little display and my throttle isn't working. Any ideas what it could be? Checked all the grounds already and they all seem to be good. Everything was working great until I put the new batteries in. Also, fuse 80 and 81 don't have power, but they aren't blown.
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Does it have a battery cut off switch? Those go bad.
  4. Lspilot82
    226
    88
    Aug 8, 2010
    Is that the thing on the terminal with a little red button? If so it has one and we're getting power coming out of it.
  5. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
  6. Lspilot82
    226
    88
    Aug 8, 2010
    I'll look and see if I have one. You think they'll cause none of the instruments to work and the throttle not to work? The truck starts and runs, just won't accelerate.
  7. Lspilot82
    226
    88
    Aug 8, 2010
    Also fuse #80 vehicle ECU/water and #81 eng mgt system B has no power going to it. The fuses aren't blown .
  8. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    The truck wouldn't do anything if you have a battery lockout, so you can rule that out. Are you sure you connected all the wires to the batteries it sounds like something is definitely not connected.
  9. Lspilot82
    226
    88
    Aug 8, 2010
    Everything has been checked and rechecked again. We've pulled off the cables, cleaned them all and reconnected them. We made sure power was coming from every cable that we hooked up, including the small ones. I'm beginning to think it's the ECM since two of the fuses don't have power going to them in the fuse box.
  10. Tombstone69
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    When the fuses to my ECM became a little bit oxidized, the truck ran but it ran horribly, missing at idle and the best I could do was about 1700RPM. I replaced both fuses no problem. I too, thought the ECM was bad, I was wrong.
    baha and Sani101 Thank this.
  11. Lspilot82
    226
    88
    Aug 8, 2010
    I'll replace them just too see, but everything was working great earlier until I put new batteries in. Just put the new fuses in and it didn't fix the issue.
    baha Thanks this.
