Truck starts shaking when fuel tank get half way empty
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Doggpoundtrucking, Mar 24, 2023.
  1. Doggpoundtrucking
    Doggpoundtrucking Bobtail Member
    Mar 19, 2023
    I have a 2014 freightliner with a DD13 engine and I e noticed that when fuel tank get half way empty the truck starts to shake or vibrate more the the regular, when I fill up the tank again it goes back to Normal any suggestions what it could be ??
  3. 201
    201 Road Train Member
    12,641
    25,975
    Apr 16, 2014
    high plains colorado
    :scratch:,,:dontknow:,,by golly, that's a new one. There is no valid reason why a fuel level would make the truck shake. Years ago, all the trucks shook, so maybe that was true,,,we just never noticed. Sounds like a bad U-joint.
    Rideandrepair Thanks this.
  4. Ruthless
    Ruthless Road Train Member
    9,101
    90,263
    Aug 28, 2010
    The City.
  5. SmallPackage
    5,704
    18,231
    Dec 20, 2019
    Marion Texas
    If the tanks are under the doors and up against the front steer axle springs then check rear steer axle spring hangers. See if bushings are worn out. As tanks empty out the weight on the front springs decreases and the ride height may rise changing the stress and angle on the hangers.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,910
    Mar 15, 2021
    It shakes because it's a freightliner..
    You nned to give more infor like only when its moving ? Or all the time ? Or only when idling ..
    Its called process of Elimination
    Could be engine related could driveline
    Could be the fact it is a Freightliner and that what their suppouse to do
    201 and Rideandrepair Thank this.
  7. SmallPackage
    5,704
    18,231
    Dec 20, 2019
    Marion Texas
    Calmdown. Or men in white coats are gonna kidnap you, straight jacket you, and strap you to a swamper seat in a crapcadia and make you ride 3 coast to coast turn arounds. Lol!
  8. Last Call
    7,568
    45,910
    Mar 15, 2021
    I have standards ..there will be a stand off ... they will not take me alive .. lol..
    Rideandrepair and OLDSKOOLERnWV Thank this.
  9. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    personally, i'd keep the tanks half full.
  10. OLDSKOOLERnWV
    18,940
    285,464
    Lol!!! I see what you did there….
    Rideandrepair, buddyd157 and Last Call Thank this.
