Truck won’t start assist please
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, Jul 22, 2020.
Hit the starter with a hammer, ignition, does power come on by turning key ,ground cable
Daycabinit Thanks this. -
see if all wires are tight on starter
Bean Jr. Thanks this. -
Try jumping the terminals on the starter. I’ve replaced a starter before and ended up with a junk starter.
rachi Thanks this. -
Did you just replace starter?
What noise do you hear when you try to start.
Year, make,model,truck +motor. -
Does it have a clutch safety switch? Try lifting clutch pedal
rachi and Cattleman84 Thank this. -
Is it an auto and in neutral?
Cattleman84 Thanks this. -
Starter relay, you can jump it with a pair of pliers
If it is an auto it needs to be in neutral... If it has been parked long enough to loose air pressure and it was left in gear, then you will probably need to air it up by connecting your red trailer line to the red trailer line of another truck and pushing in the red knob in both trucks. Once it has air pressure again it will shift to neutral and then it will start.
Accidental Trucker, rachi and InTooDeep Thank this. -
Also check your grounds.
