Truck won't shift into high gear HELP
Discussion in 'Freightliner Forum' started by Mrnice81, Mar 10, 2014.
  1. Mrnice81
    Mrnice81 Bobtail Member
    28
    6
    Jan 1, 2014
    Pa intrastate
    Hello fellow truckers ,
    i have a 2000 freightliner century with detroit 60
    im just now pulling out the warehouse dock in first gear, everything was normal until I tried to float in 2nd gear.
    it won't pop in second and the engine revs itself , I tried 3rd gear and same, the engine just revved by itself without being in gear.
    next I start in first gear and flipped high gear switch to 2nd gear an it went in gear then 3rd gear and the engine lost power as if I was in neutral .
    now I'm in first gear and double clutch to 2nd 3rd and 5th without failure, all seems normal but I can't double clutch into 6th gear. High gear and so forth
    What hat could be the problem? Transmission problem? Burnt clutch?
    Please help, any response would be a great help
  3. Mrnice81
    28
    6
    Jan 1, 2014
    Pa intrastate
    Just had oil change , tranny oil and front differential oil replaced
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    What trans? super 10 or reg.10 speed
  5. retlow8
    retlow8 Light Load Member
    51
    11
    May 31, 2009
    Florence, IN
    Flip your splitter!
  6. koncrete cowboy
    koncrete cowboy Medium Load Member
    638
    331
    Jun 11, 2013
    Pennsylvania
    Pop off the inspection cover and look inside with a flashlight..sounds like oil on the flywheel or clutch dis c.....if thats ok...look for air leaks on the tranny lines. Andat the box...
  7. koncrete cowboy
    638
    331
    Jun 11, 2013
    Pennsylvania
    It couldabeen over greased when u had it work on(throw out bearing)...and you got a slpry flywheel...thats my best guess without being there
  8. koncrete cowboy
    638
    331
    Jun 11, 2013
    Pennsylvania
    Check fo signs of a broken spring on thepressure plate...have someone bump the starter while u look...sure wish I c ould be of more help...
  9. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    post this question in the garage section. best of luck getting it straightened out.maybe whomever serviced the tranny knocked something off or it is in the splitter.prob simple repair.hopefully
  10. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    sounds to me like you need a new synchronizer
