Truck wont shift *PLEASE HELP*
Discussion in 'Freightliner Forum' started by najera.hector, Aug 13, 2016.
  1. najera.hector
    najera.hector Bobtail Member
    I have a Freightliner 2002 Columbia Detroit Engine 12.7,
    For a while the ABS light has been on and finally the truck would not go into neutral, therefore i could not move it. The truck turns on and everything, but it wont show any gears on the dash. I know that it is in neutral, but the system wont recognize it or anything on the dash. Next, this small black box in the chases near the gas tanks melted, [​IMG] [​IMG] . Before, it would run fine for a while and then start jerking and stop. Apparently it is not the speed sensor. I've taken it to multiple mechanics and electricians, no one can help. What could possibly make my truck malfunction like this?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Is this a automatic transmission?
  4. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    No way to really know unless u have a complete wiring schematic on that model.
  5. Hamburger71
    Hamburger71 Medium Load Member
    349
    235
    Jun 18, 2014
    North Carolina
    I drive a T680 with an auto transmission. Last winter we were in the middle of Wyndmoaning (Wyoming) and while driving the truck stayed in 7th and wouldnt change, even in manual mode. I pulled off, it went to neutral, and there we stayed until we were towed into Cheyenne. It took about an hour to fix and was very cheap. What happened? One of the wires broke........just one wire. Shut down the entire truck.
    You can try to find the issue, but I sugggest, unless you really know what you are doing, take it to the shop and have them look it over. You may be lucky like we were and it be a simple fix.
    x1Heavy Thanks this.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    this is very important what does it show on the display and what kind of trans do u have zf meritor or eaton fuller do u have a clutch pedal or no.
    x1Heavy and truckthatpassesyouby Thank this.
  7. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    the small box on the chassis should be your power distribution module and needs to be replaced that might have a lot to do with it as well
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,132
    Mar 5, 2016
    White County, Arkansas
    ABS.
    Anti lock braking system.
    I do not understand where shifting comes into play? Unless it is one computer dealing with two paths of binary channels for two seperate systems on the 18 wheeler itself. One for transmission and other for anti lock braking?
    Do I have that right? Or did I totally blow smoke and should be taken out to the woodpile to be shot tonight?
  9. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    usually the communication for the data link goes thru abs some of the time depends on the truck most frl are like that and they are just a pain in the ###.
  10. roadranger550
    roadranger550 Light Load Member
    143
    131
    Jun 20, 2016
    Has to be, the way he describes it. Just another reason to have a manual transmission.
