truck won't start
Discussion in 'International Forum' started by walter wells, Mar 11, 2014.
  1. walter wells
    walter wells Bobtail Member
    5
    Mar 11, 2014
    06 9900i, won't start, clicking sound from dash...any solution?
  3. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    The clicking sound will be your relays, and they make that sound in normal operation. I mean, check the relays, but with what little info there is, sounds like your starter is giving up the ghost. Have you had any hesitation previously from the starter when you went to crank it? Maybe it would hesitate for a second before cranking over?
  4. walter wells
    5
    Mar 11, 2014
    Starter is newish.the clicking sounds more like two pieces of metal hitting together
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Sounds like a battery or connection issue. If you're able have someone turn the key while you watch the starter. A poor connection you'll see sparks fly. The hold down nut can be a hair loose or there is corrosion built up. That's where I'd start.
    dustinbrock Thanks this.
  6. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    batts may be discharged, try jumping it off
  7. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    The relay essentially is two pieces of metal clicking together to make the connection once you energize the power side. I would check the main ground from the starter to the frame, I had this issue with my 9300
  8. Mara
    Mara Light Load Member
    50
    26
    Jan 31, 2014
    Franklin, WI
    sounds like my issue...did you check your circuit breakers because I have the same clicking sound and my eaton shift tower circuit blew and it's a pain in the ### to order..
  9. Mara
    50
    26
    Jan 31, 2014
    Franklin, WI
    however, I have an automatic!
  10. walter wells
    5
    Mar 11, 2014
    Thank you all for the idea's. I will consider them all.
  11. Mara
    50
    26
    Jan 31, 2014
    Franklin, WI
    No problem..im in the same boat..she still wont start..
