Truckin' to Alaska - Need permit help
Discussion in 'Ask An Owner Operator' started by Winchester Magnum, Feb 20, 2010.
  1. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    'Preciate the kinds words Larry, back atcha. I called comdata and they were useless, at least the person I talked to anyway. I never even thought of callin OOIDA. Worth a shot
  3. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    Found a link that might help you plan http://www.dmqis.com/Canada.html
    I would double check everything with each province especially if you are over 244'' the other thing is the national saftey council , you might have to get a rating with them and you are aware our roads up here are 2 lane goat trails??? for the most part.:biggrin_25515: and fuel is real expensive in comparrison
    Winchester Magnum Thanks this.
  4. montana cowboy
    montana cowboy Bobtail Member
    35
    18
    Feb 13, 2010
    kindersley saskatchewan
    might check with Lyden as they have terminal in Edmonton, Alberta. They bring freight from lower up to there and sometimes switch,just my opion!
    :biggrin_25514:
  5. coastie
    coastie Road Train Member
    If you go to Anchorage, you watch out for the Great American Bush Company. You may never want to leave.
    Alaska, the land of the Midnight Sun, if you do not like the weather Wait 10 min and it will change. Beautiful sights to be seen. I been there, also to Juno, Ketchacan, Kodiak, Adak, Kiska, and Dutch Harbor. Most you would not be able to go in your Truck though.
    Aug or Sept? are you sure then? Carry your snow chains then.
  6. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    I have been to the Alaskan Bush Company before 10-4...........(grin)
  7. Longhood379
    389
    125
    Nov 30, 2009
    Cremona AB
    A lot of the loaded trailers on Iceroad truckers 3 were spread axles ,I wonder if it would be worth your while to get in touch with somebody at one or the bigger companies in Alaska to find out if the got permits to bring the spreads through BC or AB ????:biggrin_25515:
  8. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    SPREAD AXLE; To the best of my knowledge and research, running a US style 10' 1" spread is totaly legal thru anywhere in Canada. That said, the options are to pay for and overweight permit....or....run the 20,000 pound max limit on the trailer, which is the direction I"m leaning to at this point. My bigggest question at this point is simpley the cost and or hassle of obtaining trip permits thru the various provinces that I"m not registered to run. I'd like to know if it"s as simple as paying at each POE.or what..
  9. dino6960
    dino6960 YOUDAMAN
    1,347
    4,583
    Jun 25, 2009
    florida
    try carliel. the company from ice road truckers, i talked to a recurter there, they run yukon and bc and washington along with alaska,,they might be some help just a thought magnum??????
  10. Longhood379
    389
    125
    Nov 30, 2009
    Cremona AB
  11. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    I called OOIDA, but they don't do temp permits. They directed me to a permit service they recommend, which was also useless. Called a few more "dotcomdata" type services...all useless. So, any one stop shopping for temporary Canadian permits either doesnt exist, or googling 6 ways from sunday doesnt list any who may. Sooooo, I break out the handy largecar Rand Mcnally and lookup the transportation ministries numbers for every province, and start calling. 4 western provinces, plus Alaska, will run about (aboot in Canadian speak LOL) a cool grand. Some are one way permits, others 30 day. Every transportation ministry represenative I spoke with in the 4 western provinces, were all quite helpfull and answered everything thoroughly. Nice folks!
    Most member here already know this, but to end any possible speculation on the legalities of running a 10' 1" spread thru SK, AB, BC, and Yk....it's totaly legal, but limited to 9100 kilos/20,000 pounds total on the trailer. The Yukon treats a 10 1 the same as a closed tandem weight wise - 17,000 Kilos/ 37,500 pounds. That is straight from the scale master I talked to in Whitehorse. Kind of irellevent tho, since you cant get there that heavy going thru AB/BC. Manitoba and east I never called.
    Alaska is the most expensive, surprisingly to me, at $360.00 for a 30 day.
    dino6960 Thanks this.
