Truckin' to Alaska - Need permit help
Discussion in 'Ask An Owner Operator' started by Winchester Magnum, Feb 20, 2010.
  1. PinkPedal
    PinkPedal Light Load Member
    122
    87
    Feb 25, 2010
    Fairbanks, AK
    LOL! Yeh, break up is coming soon! Eek.
  3. Northernblue
    Northernblue Light Load Member
    81
    243
    Sep 25, 2008
    Left Coast
    Been there myself. Thought I was in Heaven.:biggrin_25514::biggrin_25526:
  4. PinkPedal
    122
    87
    Feb 25, 2010
    Fairbanks, AK
    LOL! A lot of the guys I work with on the Slope frequent that establishment when they fly into Anchorage for a hot toddy before home(they do have a DD).
    OMG...some of the stories! LMAO! Thank gawd no one is dumb enough to get photo documentation!! It's all good! Nothing *that* bad (or good depending on how ya look at it!
    I really do love working with guys!
  5. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    When you talked to the "permit people " in canada did any of them mention insurance ?
    I know BC has some weird rules , either you register your insurance with them well in advance or they want you to buy a temporary policy. SK may be the same. :biggrin_25526:
  6. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Bc requires "financial responsibility"....or you can buy it for $60, in addition to the temp permit.
  7. montana cowboy
    montana cowboy Bobtail Member
    35
    18
    Feb 13, 2010
    kindersley saskatchewan
    sorry for wrong info. as you see 17000kgs is 37500lbs! good luck also if anything i due or help ask!
  8. Mike101
    Mike101 Light Load Member
    65
    15
    Jun 9, 2009
    Quincy Mass.
    If you can only pull 20,000 on spread axle, how much can you put on closed axle. I have always to take a ride up there. Looking forward to more info. Thanks
  9. truckinusa
    truckinusa Light Load Member
    193
    42
    Apr 1, 2009
    Ponca City, OK
    I'm assuming it is 34k to 40k but with a permit I hauled a load into Ontario and Quebec with 54k on my tandems and over 100k gross. Don't know if that is possible in all provinces? If you have the extra hole to make a 6' canadian spread or you run a tri axle I'm sure its much higher. A canadian spread is essentially a triaxle missing the center axle.
  10. montana cowboy
    35
    18
    Feb 13, 2010
    WM
    if you go make roads you travel on in Sk can take your weights, roads are diff. class, as winter weights will be removed March 05, 2010 # 12.01am untill around Nov. ? 2010.
    Now (friday) i will be putting on more miles as most roads will be limited!
    Make sure your route is what Sk. calls primary roads! Would PM you but ? not enough! LOL
    Winchester Magnum Thanks this.
  11. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Montana, I was aware that SK factors in the gross weight for the temp permit. I was impress to find they bill the old fasion way - send a bill in the mail, instead of money up front. They told me $170 for a one way trip permit (72 hrs) grossing 70,000. 'Preciate the info!
    montana cowboy Thanks this.
