Trucking company and penske lease truck
Discussion in 'Report A BAD Trucking Company Here' started by rpad139, Aug 1, 2022.
  1. rpad139
    rpad139 Heavy Load Member
    877
    562
    Jan 9, 2014
    Ca
    Any trucking company who operates a fleet of penske trucks is no good. Penske lease does poor job on truck service.
    I have witnessed trucks go 100k miles with no service done, no oil change or preventive maintenance!?!?!
    Once again, beware of trucking companies and the penske lease.
  3. jethro712
    jethro712 Medium Load Member
    604
    6,035
    Aug 31, 2014
    duly noted, thanks. btw, it says your a heavy load member, how many yrs ya got under yer belt? tia
  4. Lonesome
    Lonesome Mr. Sarcasm
    11,178
    22,947
    Dec 15, 2007
    Northern Indiana
    ANY trucking company? That's a pretty broad brush....
  5. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Especially as it's not really Penske's fault the company doesn't take the truck in for service.
    Don't get me wrong, I'm not a fan of Penske's parts changers (at least that's all they are at the local shop) but there is only so much Penske can do.
  6. rpad139
    877
    562
    Jan 9, 2014
    Ca
    The problem is the owner of stupid trucking company decides to lease 50 to 100 penske units and has no clue how to wrench a truck, or any equipment.
  7. rpad139
    877
    562
    Jan 9, 2014
    Ca
    I have some experience under my belt.
    You won't believe the work I've seen on some of the penske company trucks out there.
    I'm upset over some previous employers I've worked for. They were breaking lease terms, not taking truck in for service. Request for truck to be fixed not solved.
  8. rpad139
    877
    562
    Jan 9, 2014
    Ca
    There is a penske service center in Phoenix Arizona. They do a good job, always busy fixing trucks, doing maintenance and staying up to date...and then there are penske service in other location, horrible job!
  9. Lonesome
    11,178
    22,947
    Dec 15, 2007
    Northern Indiana
    Now in post # 1, you said....
    Now you're saying Penske does a good job. Which is it?
    That's probably why they went with a lease company like Penske, or Ryder. It ain't the lease company's fault, if the owner has no clue on how to wrench. It's as much on the company as it is on Penske to see the trucks are serviced, and problems fixed.
    The Penske location's I'm familiar with did an OK job, not outstanding, not horrible. Maintenance was always done, but other writeups were always hit or miss.
  10. Capacity
    Capacity Road Train Member
    1,499
    3,118
    Jul 28, 2019
    Neenah Wi
    Penske 14th and Deqinder Madison Heights used to tighten my fuel filter with channel locks and poke pin holes in it , idiots.
  11. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    So is the OP reporting that Penske .. it's self is a bad company ??
    Or is he saying every Trucking company that leases from Penske is bad ?
    Or is he saying Penske trucks are a POS & Every Company that's leases from them are run by stupid people ???
    Or did he just start this thread because the company he worked (which he hasn't named ) for had a stupid boss & leased trucks from Penske.. and he had a bad experience so now he's all pissed off at the world
    I need a road map to follow the direction the OP is headed but he just keeps circling the camp fire
