Hello, I have a 2011 Freightliner Cascadia with a DD15 engine. I had the DPF filters cleaned last month and now it is running with the engine & check engine light on. the yellow light for the DEF level indicator is flashing even though the tank is full of DEF fluid. It states that there is 7 faults. here is what I copied down,
1) SFU 49
523530
FAIL 31
2) CHS 71
520801
FAIL 3
3) EEC 61
4364
FAIL 18
4) CAB 33
522116
FAIL 2
5) EEC 61
3364
FAIL 2
6) EEC 61
3610
FAIL 2
7) EEC 61
3364
FAIL 17
Does anyone know what these mean ? Thanks.
Trying to figure out the fault codes my 2011 Freightliner cascadia is throwing
Discussion in 'Freightliner Forum' started by Reaper2, Feb 16, 2016.
uuu.. long list
#3 scr nox conversion efficiency low
#5 improper def quality
#6 dpf inlet pressure- not plausible
#7 def quality warning4vmach1 Thanks this. -
#1 sub bus switch missing msf
#2 Relay group 3 -Voltage above normal, or shorted to high source
#4 Temperature sensor outside air, feedback - Data erratic, intermittent or incorrect -
Your SCR module took a dump, bad nox sensor(s), or you're not getting DEF into the SCR module from the metering unit. I would need a log file to help you out if you're out of warranty.
mhyn Thanks this. -
Can someone please tell me why is all 3 lights flashing check engine,stop engine and regen light all at once everytime I try to regen it idle up pass 1500 rpm for bout 3 minutes then idle back down...PLEASE HELP
