trying to find the weight of a 2009 pete 386
Discussion in 'Ask An Owner Operator' started by Houndstooth, Jun 13, 2014.
  1. Houndstooth
    Houndstooth Light Load Member
    55
    6
    Jun 12, 2012
    Phenix City, Al.
    24.5 tires. its got a 70inch sleeper, isx cummins 485hp....13 speed, 3.55 gear ratio, 240inch wheelbase
    anyonr who runs one like this please give me the tractor weight
  3. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    Scale it and be sure. That said, we still don't know enough to tell you its weight. Aluminum or steel hubs? Wheels? Frame thickness? What kind of 5th wheel? Fuel tank size, additional equipment etc. Those differences alone can add up to 1500 or 2000 lbs. I'm gonna guess 17850 to 18000 w/ bingo fuel and driver gear. Well over 21,000 ready to roll with you in it.
    Houndstooth Thanks this.
  4. nshore harleyguy
    nshore harleyguy Medium Load Member
    342
    258
    Feb 8, 2014
    NH
    I drive a 2012 and with fuel it usually weighs in at about 17955. That's with a cummins and 10 speed
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It's been 5 years since I've weighed my 2009 but I'm pretty sure it was in the high 16's. If I could find my logbook I could tell you exactly. But like they have said there are variables. I had the big sleeper and long wheelbase too. With the reefer I could haul around 44,800.
    If you just crawled in the truck go scale empty.
  6. Boardhauler
    Boardhauler Road Train Member
    1,695
    3,295
    Dec 21, 2008
    Ballin' in it for Shakey
    Read the tag weight then add for fuel. Should be close enough.
  7. Toddsurfs
    Toddsurfs Bobtail Member
    27
    14
    Dec 31, 2013
    19000 09 386, 485 9 speed 3.55 gears right at 30000 with a 48 dorsey flat 50/50 combo
  8. Houndstooth
    55
    6
    Jun 12, 2012
    Phenix City, Al.
    ill be over the road dump trucking with it so ill def need to be sure b4 the purchase. every extra ton is big bucks at the end of the month
  9. rodpiper
    rodpiper Bobtail Member
    19
    Feb 25, 2009
    south carolina
    Like boardhauler said check the tag weight then add fuel weight. Are you going own authority or leasing on to someone else?
  10. blessedman
    blessedman Light Load Member
    296
    230
    Feb 15, 2013
    Doniphan, Mo
    Tag weight is dry weight. That is no fuel, oil, gear oil or any of the liquids.
    When you test drive it take it to a scale. Truck stop scale, feed store scale or whatever is available.
    Surely the seller will let you do that. If not I would be looking elsewhere for a truck.
