I have an Volvo 2007 780 D12 about 510,000 miles on it, the other day the light on the dash came on, TSC. I did rest set the code, after about ten mins. of driving the light came back on. I look up the codes, here what I have MID 136, SID 89, FMI 2 can someone help me out on this one.
After the light came on, about 12 miles down the road, my front drive leaf spring broke.
When thing go wrong, they all go at the same time.
TSC Light is on
Discussion in 'Volvo Forum' started by v6killer, Sep 17, 2011.
The lineament of the steering wheel was off and causing the rear wheels to fight for traction on the payment, that why my TCS light came on, there is an built-in gyro in the truck so when you turn the steering wheel it knows which wheels #is going to get the power.
cstefan Thanks this. -
ESP is deactivated becouse someone installed steering wheel wrong.
ESP compares acceleration (from ESP acceleration sensor, FDR in Germany) and compares it with steering wheel angle and seems to me truck runs straignt but steering wheel is not in center position, ESP reads no lateral acceleration and thinks that truck skidscstefan Thanks this. -
I have the same problem with TCS ..I'm at the mechanic now.. when I get an answer I'll posts the info...
ips2000usa Thanks this. -
Does anyone know where to look in vcads to calibrate the angle sensor???
About time I got over to see the tec. Who was Working on my truck, he had it calibrated. Far as I can tell, he turn the wheel all the way the the left then to the right, done!
I have the same truck and the same problem. I do believe it's got to do something with alignment on the steering wheels.
I had the same problem. The sensor is around the steering shaft just below the steering wheel. If you take off the plastic cover on the steering column it's clearly visible.
I got a can of air and blew it out real good. The just squirted some WD-40 around the shaft and it's been ok ever since. -
My sensor went bad on my truck got it replaced, does any one know how to get it calibrated, I looked in vcads all over the place, I cant find any thing in regards,
Thanks, -
I have this same code. So I am gathering that this is an alignment issue? It will also derate?
thanks
