Tug test is not a check for connection, it is a brake check
Discussion in 'Experienced Truckers' Advice' started by scoobertdoo, May 3, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    I check mine every time I pull away from a dock. I always turn when I pull out, close my doors, and then inspect my 5thwheel from the back side with the trailer and truck at 45 degrees. I dont unhook anymore (unless demanded) so there is less chance for a unhooked trailer. My short company job had me picking 3-8 trailers up a day. Still never dropped one. I have never even come close, so I don't understand how people do it aside from laziness, and now sabotage.
  3. jamespmack
    215,913
    Stop, cause 90% of the time if your gonna loose one. Its in that first turn. Check straight on. At a angle is were law of motion takes over.
    Its why I prefer Holland. Check jaws on hookup. After that all day, check handle and adjustment rod. Both in, good to go. Did not drop trailer so no concern for a high hook.
  4. OldeSkool
    OldeSkool Road Train Member
    1,757
    5,103
    Jul 17, 2018
    New Hampshire
    I unhook from my trailer 5 times a day often. I always visually check before i go. I’ve had 2 times I would have lost my trailer if I wouldn’t have.
    Radman Thanks this.
  5. Radman
    Radman Road Train Member
    2,060
    2,496
    Apr 18, 2011
    Yup, I look too everytime. I had one in winter I backed under and didn’t bump it hard enough but heard the handle click. Looked at the jaws and they were open but tight enough for a tug test to fool you. Handle was in also. Dirt, grim, and cold did it. I’m sure dirt and grim can do it at any temperature. Ever since that day I visually check it and back into my trailer firmly not these soft hooks like I see others do cause they don’t like feeling the bump when backing into it.
    Had a co worker come from Salt Lake City got about 30 min from Denver the back box came off on the interstate at 65mph. Luckily it was in the dead of the night. Said he checked it. Did a tug test and handle was in.
    I figured it was same thing happened to me but he didn’t catch it.
    tlalokay, flood and OldeSkool Thank this.
  6. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    Lost count of the times I started to pull forward, then had to set the brakes, take off my seatbelt, just to go check. I never leave without looking. Something I'm paranoid about.
    Jack of shame is one thing, but I don't feel like fixing all my trailer connections, and I REALLY don't feel like killing some guy's wife and kids.
  7. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    I get under and look WITH A FLASHLIGHT every single time. My locking jaw has a shiny rub spot on it. If I see that spot......I know I'm good. I see guys back up, hook up the lines, raise the gear and go. They are right there and don't take the extra 5 SECONDS to check the jaws. I don't get it.
    OldeSkool and not4hire Thank this.
  8. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
  9. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    What is the lesson in this video? The world is full of as holes. Always check your kingpin before you move your truck. I started the habit during my training almost 5 years ago. It is just automatic for me now. Also, When you park, set your trailer brakes, pull forward to put tension on the jaws, then set your tractor brakes.
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    When your greasing the 5th wheel take a putty knife and scrape off the old grease let's you inspect the area better and keeps it cleaner
    Qbf594, not4hire and Dockbumper Thank this.
  11. '88K100
    '88K100 Road Train Member
    1,330
    2,929
    Aug 23, 2020
    Always do a visual of 5th wheel jaws. Tug test is not correct and certainly not infallible.
