Tunes and Mods. for pre-egr Cummins
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BIGMIKE1, May 27, 2011.
  1. BIGMIKE1
    BIGMIKE1 Light Load Member
    257
    86
    Jan 23, 2010
    Looking for suggestions to improve power and mileage on my 03 pre egr 400 cummins isx. Planning on doing donaldson straight thru mufflers. Any info on tunes or any other mods that anyone has experience with would be appreciated.
  3. Pappa Bear
    Pappa Bear Light Load Member
    105
    22
    Dec 20, 2010
    Springfield, OH
    Your best bang for your buck would be to have a cummins shop turn your ECM up as high as it will go without changing parts. You might be able to go as high as 550hp/1650tq without changing any parts. I think it's around 300 bucks to increase the hp. They can tell you how high you can go when they plug in the computer. If you want big hp you could probably turn it into a signature 600. This would probably cost around 10 grand and be a little complicated. Or have PDI flash your ECM and change your exhaust manifold and turbo. This would give you 750hp+.
    BIGMIKE1 Thanks this.
  4. Diesel Dave
    9,249
    29,574
    Jan 20, 2010
    Hesperia, Ca.
    There is a thread in here on how to bypass the EGR on cummins isx without the check engine light going on.
    The Challenger Thanks this.
  5. BIGMIKE1
    257
    86
    Jan 23, 2010
    Would that be the best route for fuel mileage if i have cummins turn it up, or go the route with a bullydog tuner. As far as the PDI flash ive heard some not so good things.
  6. BIGMIKE1
    257
    86
    Jan 23, 2010
    D.Dave i dont have an egr, its pre egr isx.
  7. Donk
    Donk Have a Cup Of Concrete
    1,643
    9,232
    Apr 27, 2008
    unless your going the whole hog, set the thing at 500.
    The way the tunes make their power, you dont notice a difference anywhere except the diesel pump when you fill it.
    i should have never wasted the money turning mine from 500 to 565.. amounts to the same thing. should have put the 600 tune in it.
  8. Pappa Bear
    105
    22
    Dec 20, 2010
    Springfield, OH
  9. BIGMIKE1
    257
    86
    Jan 23, 2010
    Does anyone know what the boost pressure is supposed to be on these pre egr isx's im only getting about 28 at the most. Asked the kw dealer about it he says its within specs. most other trucks ive had ran at least 32 or more.
  10. Donk
    1,643
    9,232
    Apr 27, 2008
    sounds about right, mine only makes 32 at full noise.
