Tuning a 12.7L Detroit for fuel milage only?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Sep 21, 2012.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    495
    315
    Feb 12, 2011
    Hillsboro Oregon
    If one were to retire his old truck from service, but want to use it as a camper for those seldom allowed vacations, is it possible to tune or otherwise modify a large diesel such as the Detroit 12.7L for fuel mileage only?
    Currently 430hp. Bone stock configuration. 300hp or less would do all that is needed, but am not going to change out an engine for a camper. I am just curious what might be possible to gain some fuel mileage?
    The front driver is being removed. Fifth wheel plate gone. Full fenders. The truck is a Peterbilt 377 sbfa. It has no external air cans, frame mounted horns and under frame exhaust. So it's pretty slick thru the air already. What else can I do to gain fuel mileage?
    Thanks.
  3. Ruthless
    Ruthless Road Train Member
    8,948
    88,124
    Aug 28, 2010
    The City.
    gear it w a lower rear end ratio/drive it slower. i.e. go from 3.70 to 3.08 or lower.
  4. little cat 500
    2,053
    1,098
    Jan 17, 2010
    Abbottstown PA
    gearing it alittle taller should be about all you realy need not going to be pullin 80'000 pounds any more
  5. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    First, turning down HP may not get you better fuel mileage. It's been proven TURNING up the HP gets better fuel mileage. The key to fuel mileage is your RIGHT FOOT. You can have 600 HP, but if you shift 1,400-1,500 you will never use that. Watch your speed too. When you're in the mountains, you get better fuel mileage with MORE power. MY dad had a Series 60, after having it derated to 455 it wouldn't climb as good and would lose fuel mileage compared to the 515 setting. Besides, turning up the power you will get better torque and won't have to use as much power to get going.
  6. Deezl Smoke
    495
    315
    Feb 12, 2011
    Hillsboro Oregon
    Thanks. I'm geared at 3.36 now with a super 10 and low pro 22.5s. I do have a set of 11r24.5s that would sure make it look good. May have to ponder that idea.
    I dont want to de-tune it per se', but I was wondering if there is a way to fiddle with the timing or turbo sizing, etc. Since it's just empty travel tractor, even the steepest hill I'd ever encounter would'nt move the egt gauge much off idle temp.
  7. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    Believe me, get as much power as you can safely handle. Think of this way, if you have 600 HP and use half throttle, its 300 HP you're using. Ok, not very accurate. The less effort your engine makes, the better fuel mileage.
  8. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    That's kind of a myth in the industry that needs to die. Two engines making 300 hp yet one is rated at 500 and the other at 600 are working the same. They're both making 300 hp. Horsepower is the rate at which work gets done. Pushing a little less on the throttle means nothing with these electronic engines. I could make one that puts out 500 hp within the first 20% of throttle position and you'd have nothing but an on/off switch. But hey, you don't have to push on the pedal hard, so it must be better right?
    To be honest I'd rather have an engine with a slightly mushy pedal, that way it's easier to drive in bad weather.
  9. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    I have an 8v71, 6V92T and 11.1 Series 60. Electronic pedals are nice.
  10. rebel127
    rebel127 Light Load Member
    296
    149
    Feb 28, 2011
    monroe ct
    Tune and turbo will help a truck hauling loads but in your case i think you would be better with some ecm tuning to adjust the timming and and fueling. the stock turbo will respond great and should do the job because at the weight from the camper you will not build heat enough to drive a turbo that would work well on a loaded truck.
  11. Deezl Smoke
    495
    315
    Feb 12, 2011
    Hillsboro Oregon
    That's what I was looking for. Can most certified shops do work on an ecm that is in spec now?
    I was actually thinking that I might already be below what it takes to drive the turbine of the stock turbo with any efficiency. I dont want to get a lot wrapped up in the project, but I'll be paying full pump price for fuel and at that, a couple thousand dollars will pay back quickly at even just 1mpg.
