Turbo Exhaust Pipe Part Number?
Discussion in 'Freightliner Forum' started by Willis Inc., Nov 25, 2021.
  1. Willis Inc.
    Willis Inc. Bobtail Member
    44
    30
    Nov 2, 2020
    Harrisburg, PA
    I have a 06 Century with Detroit 14 L. Turbo exhaust pipe OEM part #04-21016-008 with no pyro fitting. I want to change it to the pyro fitting version. I think it is part #04-21016-009 but I'm not shore. OEM 2 bends 60 Deg. 58 Deg.,9" offset. Dose anyone for shore which pipe it would be?
    Thanks, Willis
    jamespmack Thanks this.
  3. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    drill a hole in it. weld a threaded boss.... will be cheaper.
  4. jamespmack
    216,333
    Rideandrepair Thanks this.
  5. jamespmack
    216,333
    Link address as strange as it looks is Chrome Depot Ohio.
    Other if you wanna spend some money. Get oem number. Google BT tubes in PA. They make them in stainless and can add egt bung to OEM part. No issue with quality. I have bought exhaust and coolant pipes from them. Nice stuff.
    Rideandrepair and Willis Inc. Thank this.
  6. Willis Inc.
    44
    30
    Nov 2, 2020
    Harrisburg, PA
    BH tubes, exhaust for this daily work truck is a little much. If I know which part#, Grand Rock will be on it. The OEM non pyro one that's on it will be junk by this spring.
    Thanks for the input, guys
    Willis
    jamespmack and Rideandrepair Thank this.
  7. Rideandrepair
    17,448
    56,617
    Aug 8, 2015
    I bought an ISSO pyrometer from Superior Diesel n Detroit. Also a probe that came with a bung to be welded on. Wire kits sold separately. Four States sells wire kits also. I think I got the wire kit from 4 states, it was longer, than others, along with a bung. So now I have an extra. Drill a hole, and weld it on within 3” of turbo. Chrome Depot cheaper than the Dealership.
    Willis Inc. and jamespmack Thank this.
  8. Willis Inc.
    44
    30
    Nov 2, 2020
    Harrisburg, PA
    Turbo pipe 04-21016-008 no pyro, 04-21016-009 with pyro, same bends.
    QUALITYTRUCK and Rideandrepair Thank this.
