turbo fins damaged
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Apr 6, 2014.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    181
    18
    May 3, 2011
    Des Moines, IA
    Hi, i have about four fins on the air intake side damaged, is it possible to replace wheel or do i have to replace the whole turbo, thx
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    The question is why were they damaged? Without answering that question nobody can help you. Was it due to:
    - Thrust washer damage, whole turbo replacement is required
    - Overspeeding the turbo, turbo should be rebuilt/replaced
    - Foreign objects entering the turbo, it's possible to just replace the wheel
    It's also something that a home mechanic shouldn't do because the turbo needs to be balanced.
  4. ColumbiaBoB
    181
    18
    May 3, 2011
    Des Moines, IA
    Plastic bag got sucked in, there is no shaft play.
  5. passingthru69
    Ok, how did a plastic bag get sucked into the turbo.. Just curious.
    And if the story involves beer this might be kinda funny
    rollin coal and Cetane+ Thank this.
  6. Heavyd
    Heavyd Road Train Member
    7,769
    6,208
    Feb 4, 2009
    Wheel cannot be replaced separately. You install a new/reman turbo.
  7. ColumbiaBoB
    181
    18
    May 3, 2011
    Des Moines, IA
    Is replasing turbo on detroit egr 14 same as in non egr, i have replaced few non egr turbos but never egr, just wondering, thx
  8. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Last time I checked they still sold turbo parts individually if that's the way you want them.
    To the op, a reputable shop should be able to swap in a new wheel for you depending on the turbo, there may be such a case as you need to buy the chra but you will be able to keep your housings.
  9. ColumbiaBoB
    181
    18
    May 3, 2011
    Des Moines, IA
    Well, new turbo is over 2k so if they could replace wheel i would go that way, also could freightliner replace wheel, i'm in st louis any shops around here who could do this, thx
  10. kat man
    kat man Light Load Member
    234
    195
    Nov 29, 2009
    orleans in
    Area diesel service inc at carlinville il they have it all'
    ColumbiaBoB Thanks this.
  11. ColumbiaBoB
    181
    18
    May 3, 2011
    Des Moines, IA
    Thx, i will call them tomorrow, just wondering whats turn around, could they do this in one day
