Turbo problem d13
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr.Cj, Feb 15, 2022.
  1. Mr.Cj
    Mr.Cj Bobtail Member
    Feb 15, 2022
    Thanks Received:
    I'm having issue with my 2012 vnl Volvo d13 ishift we replaced the turbo and turbo actuator afterwards I noticed that there was a lot of oil leaking from the turbo and the turbo actuator and all over the bottom of the truck I'm also having problem with the truck I will be driving on the road and all of suddenly I would lose power press the gas pedal and nothing then after about 2 minutes later it would go back to normal sometimes I would get check transmission also when reversing the truck will jerk and sometime it will not go at all sometimes I would have a long crank to start the truck in the morning
    I have changed the oil and oil filter air filter fuel filter
  2. Siinman
    Siinman Road Train Member
    Mar 5, 2017
    5,435
    Thanks Received:
    13,973
    Kansas City, MO.
    You are having transmission issues. This could be a few things but it most likely is caused by the TECU ribbon. On the turbo did you have it programmed when you changed it out?
  3. Mr.Cj
    Feb 15, 2022
    Thanks Received:
    Yes
    Siinman Thanks this.
