Turbo problems.
Discussion in 'Peterbilt Forum' started by Crazyhorse202, Jun 6, 2012.
  1. Crazyhorse202
    Crazyhorse202 Bobtail Member
    17
    5
    Jun 5, 2012
    Mi
    I put a 600hp turbo on a 475-490 cat 3406e in a 2000 peterbilt. Michigan Cat is telling me that it's gonna melt down my motor because the fuel bowls are different, then a Cat dealer a friend of mine deals with in california says that I wont have any problems.
    I was just hoping to get some insight from you guys on what to do.
    Thanks in advance, Tom.
  3. Crazyhorse202
    17
    5
    Jun 5, 2012
    Mi
    Will a 600hp Turbo work on a 475/550 C-15?, I have been told that it won't get enough air and cause piston Melt down
  4. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    You won't meltdown the motor. You will have issues with high EGT's though. The reason for this is the exhaust housing and turbine wheel are bigger in diameter. This makes the turbo hard to spool, because you don't have the fuel to turn it properly with a 475-550 engine. Are you using a CAT 600 turbo or a BW OEM replacement 600 turbo?
  5. Crazyhorse202
    17
    5
    Jun 5, 2012
    Mi
    BW, What should I do to solve the problem ? Thank You
