turbocharger on 3406e cat leaking oil
Discussion in 'Peterbilt Forum' started by chuy1978, Oct 7, 2010.
  1. chuy1978
    chuy1978 Bobtail Member
    32
    Dec 26, 2009
    Indianapolis,in
    I need to know if there is and O ring gasket on the top of the turbocharger or just the flat plate just like the bottom.
    Also how hard is it to fix the oil leak.
    I am going to be working on it this weekend and need help fast thanks!!!!!!
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    i might be missing something here ,what flat plate? the only o-ring that i know about on a turbo is the 2 on the elbow that pushes into the charge side of the turbo.
  4. chuy1978
    32
    Dec 26, 2009
    Indianapolis,in
    The plate that I am talking about is the one with a square rubber gasket with the bolt holes for the bolts that go though. I believe that is the one for the bottom of the oil side. I also was needing to know if there is an o ring in the top where the oil goes in.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you take the arrangement number off the valve cover and the serial number of the engine to any Cat dealer they can give you the correct part. I would bet it is the plate with the seal ring, as an integral part of it.
  6. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    i have never seen that on a 3406E turbo unless you have a off brand turbo. except for the return oil tube ( 2 bolts and a metal gasket with a o-ring inserted in the middle. if so just take your arrangement # and serial # to cat and they will get you the right one.
  7. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    Most and I'll repeat this MOST 3406E engines use a intergrated seal and plate at the oil lines for the turbo
    supply line is part number 126-2704
    return line is part number 126-2702
    Now I've also seen a 5EK with an O-ring on the oil supply line........... part number 6J-2245 or intergrated seal and plate 198-6068
    This same engine also could have used an O-ring on the return oil line........ part number 6V-6228
    The best thing to do is have the parts people look it up with your particular engine serial number.........but the above mentioned 5EK has both part numbers listed for these lines..........if you have this problem then tear it down and see which you have and hand carry your old parts in to allow the parts guy to match it.
  8. hotrodmech
    hotrodmech Bobtail Member
    williams lake bc canada
    some turbos have o ring seals and others have metal and rubberseals on the pressure side
  9. RocketScott
    RocketScott Medium Load Member
    579
    948
    Apr 10, 2013
    Kentucky
    The turbo on my cummins 444 has oil leaking out of where it connects to the exhaust pipe. I don't want to hijack the thread but is that what you are seeing?
  10. JohnP3
    1,594
    683
    Feb 21, 2010
    On a 444 you have to be careful they are notorious for having fuel slobber if idled and not covered in. You can get oil dye Cummins part # 3376891.
    do the test as written on the bottle it is great stuff and will not hurt the oil.
    Just a thought!
  11. RocketScott
    579
    948
    Apr 10, 2013
    Kentucky
    I'm not really picking up what you're putting down. What is fuel slobber? The engine mostly idles while I opperate the crane, the truck only gets driven once a month, maybe two. What do you mean by covered in?
