TURBO'S ON ALL THE MID 90'S CAT 3406'S?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Toddk, May 26, 2020.
  1. Toddk
    Toddk Bobtail Member
    22
    Jan 2, 2020
    HELLO, I HAVE A FACTORY LOW HP CAT MOTOR. ITS A 375 HP (5EK). IM GONNA TRY AN HAVE IT BUMPED UP TO A 425 HP! ITS AN "E" MODEL! BUILT 0CT. OF 1995. SO, FOR ALL THE THINGS ALREADY MENTIONED, IT HAS A REAL SMALL TURBO! SINCE IM TRYIN TO GO TO 425 HP, ID LIKE TO PUT A FACTORY 425 HP TURBO ON IT! THERE ARE TONS OF B AN C MODELS THAT ARE FACTORY 425 HP! CAN I TAKE A TURBO FEOM.ONE OF THOSE AN PUT ON MY E????
    THANKS IN ADVANCE FOR ANY HELP....
    HAVE A GOOD DAY/NIGHT...
  3. Rideandrepair
    17,380
    56,398
    Aug 8, 2015
    The emodels I remember were 435 hp. That’s your turbo, don’t know #s, but can’t be hard to find. Might want to check injectors and programming info, maybe even Cam? I don’t know. Maybe you already have everything. Just turned down.Need to run the #s by a Cat dealer, or expert on the forum here.Those are great engines.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Put a 177148 Borgwarner on your E.
    Its rated at 425-550 if I'm not mistaken.
    It will work just fine at 425 rating.
  5. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    You can put any turbo on any motor, theyll just have different characteristics. You need to actually know about turbos to make good selections. Theres a lot to it.
