hello every one I have a question about the borg warner turbos, I have a 5ek cat I have put a marine cam in it, it was built for heavy haul so it already has the bigger injectors, my question is does anyone know the best borg warner turbo to use I need a part number
turbos
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slowhandpete, Apr 21, 2015.
Marine cam and bigger injectors tells us nothing really. What is the cam part number, injector number? Also do you know if it was loaded with the factory 5ek pistons or something different that would change the compression ratio
5eks only had different injectors if they were rated at 550hp.
As wore out said get parts numbers and come back. -
I prefer just the turbo.
How does that pertain to the original question?
And 6nz file.
6nz file will not work in a 5ek
Again, how does this relate to the original question?
I got a c-15 with mbn junk file. With 3406e is a different story. If 3406e, nwg turbo, 550 hp file, and ceramic coated manifold.
Which non waste gated turbo, which 550 file.
